proportioning valve
Old Jul 15, 2019 | 09:26 PM
kodpkd's Avatar
kodpkd
Default proportioning valve
I'm replacing the MC and proportioning valve on a 68. The 68 proportioning valve has 2 inputs, 2 outputs. One output for the rear, one for the front. The new valve has 2 seperate ports for the front, and still just one for the rears. Should I plug one of the ports for the front and just use the existing line, or make 2 seperate lines for the front left, front right?
Old Jul 15, 2019 | 11:14 PM
7T1vette's Avatar
7T1vette
Is is designed to have separate outlet fittings for left and right in front. That is to eliminate a single crossing line for the full width. Not sure whether that is for safety in some regard or strictly for cost savings. Maybe both....
Old Jul 15, 2019 | 11:35 PM
ignatz's Avatar
ignatz
Maybe it is a series or parallel trade with regard to fluid movement? I would go with the two lines.
Old Jul 16, 2019 | 05:26 AM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
cant you find the proper proportioning valve? heres a 68 https://www.paragoncorvette.com/p-35...ing-valve.aspx apparently its another 67-68 part like the front spindles and bearings
The 69 vavle looks like the 68 one except for the mounting bracket
https://keenparts.com/corvette-parts...partnum=500452
Old Jul 16, 2019 | 08:26 AM
kodpkd's Avatar
kodpkd
Yes, I have seen these. I bought a master cylinder with the proportioning valve included. Just wondering what difference it might make to install the new style.
Old Jul 16, 2019 | 10:40 AM
Duke94's Avatar
Duke94
This valve was a GM "corporate" design and was used on a multitude of platforms. Depending on where the valve got mounted, the 2nd angled front outlet port may not be used. When in OE production, the port just didn't get machined, but to make it "universal", the aftermarket just plugs it on those applications that don't use it.
Old Jul 16, 2019 | 11:27 AM
kodpkd's Avatar
kodpkd
Thank you. That's what I was hoping for. I did see the other design that had the angle part,, and no exit port. I will get a plug... This way I can install it with what ever port that works the best. I'm not sure what the deal is, but it was hard to find a disc/disc Master cylinder and prop valve.
To proportioning valve
