Three... two... one... lift off!
Old Dec 18, 2017 | 01:18 PM
  #361
SB64's Avatar
SB64
Default Vette
Great tutorial pictures and nice work. Keep it up!
Rvzio
Old Dec 18, 2017 | 01:45 PM
  #362
SuperBuickGuy's Avatar
SuperBuickGuy
looks even better in person.
Old Dec 18, 2017 | 06:49 PM
  #363
RBrid's Avatar
RBrid
Originally Posted by doorgunner
Good pictures.
Rvzio
Thanks guys! Rvzio - wishing you the best for the coming days.
Old Dec 19, 2017 | 07:33 PM
  #364
SPCL FX's Avatar
SPCL FX
Been a while but it looks like everything is coming along nicely! Merry Christmas RBrid AND SUPERBUICKGUY !
Old Dec 19, 2017 | 10:02 PM
  #365
js1977's Avatar
js1977
Wow!!!! Just wow!!! Amazing work! Please let me know if you ever enter in any car shows when your done! I'd love to see this beauty in person.
Old Dec 21, 2017 | 02:49 PM
  #366
RBrid's Avatar
RBrid
Thanks SPCL FX. Merry Christmas to all of you too. May all your vette dreams come true.
Hey js1977, thanks, I suppose you have a '77 too. I'll definitely go to a few events when it's done. For example the Redmond Town Center's Saturday morning Cars & Coffee, the Kirkland Classic Car Show and the Issaquah XXX Corvette Show...in 2021 hopefully. Looking forward to meeting you.
Little update: I started to glass the inside of the fender. Outside temperatures are around 32 degrees. With the heaters set around the medium setting, my little booth's temperature is 70 degrees. Yeah!
As a side note, since I received Doug's headers I have read two unfortunate news:
#1 Apparently I'll have to dimple the driver side to accommodate the steeroids rack and pinion.
#2 I can't use heads with angled spark plugs. Of course the heads I intended to use for my 427 SBC use the angle style (Trick Flow® Super 23® 230 Cylinder Heads for Small Block Chevrolet TFS-3241T002-C03). Their 70cc combustion chamber allowed a 10.2 static CR. The best second choice I could find are the Dart Pro 1 230cc. Their 72cc chamber brings down the CR to 9.8
Old Dec 21, 2017 | 03:51 PM
  #367
js1977's Avatar
js1977
I actually just picked up a 75, the name comes from a 77 T/A I once owned, it was just easier to keep the name then remember/change it. Haha! I took my GTO to the Kirkland and Issaquah XXX shows this past summer, I had a great time. Look forward to seeing you car there (hopefully before 2021, haha!). And again awesome work!
Old Dec 30, 2017 | 12:14 PM
  #368
scottjamison's Avatar
scottjamison
I look forward to meeting you! I live just down the street from XXX on the side of Cougar Mtn. Looks like an awesome project going on there!
Old Jan 21, 2018 | 05:01 PM
  #369
RBrid's Avatar
RBrid
Default More fender glassing
Thanks Scott - looking forward to meeting you in Issaquah with my '77.
So here's a little update. After the inner glassing was done on the fender I switched to the outer side. Here's a before and a during picture.
Old Jan 21, 2018 | 05:07 PM
  #370
RBrid's Avatar
RBrid
Default Inner fender skirt gluing
Then came the inner skirt gluing with Evercoat's SMC Panel Adhesive. I used several wooden jigs to get a precise fit. There are many dimensions to get right so that the radiator holder and hood brackets among others fit correctly later on.
Old Jan 21, 2018 | 05:10 PM
  #371
RBrid's Avatar
RBrid
Default Sidepipe fitting
I installed the driver side Doug's header and side pipe to check for clearance issues with the flared fender. No problem at all and it looks awesome!
Old Jan 21, 2018 | 05:16 PM
  #372
RBrid's Avatar
RBrid
Default Gluing the driver front fender
Finally the driver side fender was glued on. Everything went well. I barely started the coats of VPA. After those are done, the next milestone will be the removal of the passenger side fender.
Thanks for taking a peek!
Old Feb 4, 2018 | 05:57 PM
  #373
RBrid's Avatar
RBrid
Default The seam is not what it seems to be
It looks good and all but I can still feel mini-waves when I go back and forth with my flat hand. I will use dry powder guide coats to locate the high/low points and improve things a bit with VPA before applying the epoxy and polyester primers.
Old Feb 4, 2018 | 06:02 PM
  #374
SB64's Avatar
SB64
Your right all of the pictures look good. Guide coat should help you!
RVZIO
Old Feb 4, 2018 | 06:09 PM
  #375
RBrid's Avatar
RBrid
Default Off goes the last big chunk
The remaining fender took the heat and said goodbye. Here are a couple pictures before and after a first round of adhesive removal and cleaning. The car can be 0.009% lighter without the excess glue.
Old Feb 5, 2018 | 04:30 AM
  #376
SB64's Avatar
SB64
Default Vette
Nice neat work RBRID, did you try the guide coat yet? The picture you are showing is the first attempt at installing the front fender. I guess I could have gone back over your post to check myself.
Keep up the nice work
RVZIO
Old Feb 5, 2018 | 12:17 PM
  #377
RBrid's Avatar
RBrid
RVZIO
Thanks RVZIO. The picture in post #373 is of the driver side fender. I don't expect to get to the fine tuning with guide coats before the end of summer or fall.
The pictures in post #375 are for the passenger side. I just started to work on that side last week. I should be able to glue on the new fender at the beginning of April.
Then I'll work on a customized front bumper cover.
To Three... two... one... lift off!
Old Feb 14, 2018 | 09:19 PM
  #378
RBrid's Avatar
RBrid
Default No filth left behind
One step closer to being able to glue on the flared fender
Old Feb 15, 2018 | 03:43 AM
  #379
SB64's Avatar
SB64
Default Vette
Continued very nice work. I can really appreciate the folks like yourself who have taken time to keep the other areas of the car clean while working. A lesson I need to take for the future.
Very Nice
RVZIO
Old Feb 17, 2018 | 08:41 PM
  #380
RBrid's Avatar
RBrid
Default Cut and Paste
Very Nice
RVZIO
Thanks Roger! I'm a clean freak.
Here's what has happened in the last days. The grafted piece is now held in place with temporary VPA and the glassing inside and out is coming next.
