Silicone hoses - what clamps?
Old Aug 2, 2021 | 09:54 PM
herwawan's Avatar
herwawan
Default Silicone hoses - what clamps?
Hi,
I am preparing a complete overall of the cooling system of my 02 C5 (among other things, I'll do a separate post on my full project), and I am almost all set.
I tried to source rubber hoses but oh my god it is NOT easy. Availability is very scarce somehow, and my best immediate option was to go with this kit (I scored a big discount on it, so it ended up being barely more expensive than sourcing the 8x rubber ones)
Now the problem is that I most likely cannot use the regular clamp on these hoses, because of the difference in material. I am having a hard time finding the size of the hoses, and I don't have much experience with silicone. I’m looking for info on the following hoses:
8x hoses descriptions:
  • Lower radiator hose
  • Upper radiator hose
  • Throttle body to coolant pipe hose
  • Surge tank outlet to water pump hose
  • Radiator to throttle body hose
  • Heater core pipe to water pump hose
  • Heater core pipe to surge tank hose
  • Surge tank inlet to radiator hose
A big thanks to @seattle for his post here detailing the parts btw because it really helped me: https://www.corvetteforum.com/forums...t-numbers.html
Old Aug 3, 2021 | 01:14 AM
herwawan's Avatar
herwawan
I made some good progress.
Where to find t-bolt clamp specifically for the silicone hoses: http://www.siliconeintakes.com/index...6af57962b73b66
There is also some good words on the Gates PowerGrip SB Clamps: https://www.gates.com/us/en/search.p...00-000000.html
Now, hoses size… look what I found (this forum is full of information but you gotta search deep! Original post: https://www.corvetteforum.com/forums...ant-hoses.html
I guess I just have to make sense of this and good to go!
Old Aug 4, 2021 | 08:20 AM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
I used the Gates "power grip" clamps. They're like big pieces of shrink tubing......
Old Aug 4, 2021 | 08:51 PM
herwawan's Avatar
herwawan
Good to know! Do you happen to have the Gates part n. for the different hoses? It's weird it seems like they are mixing metric & imp. I can't wrap my head around it haha
  • 7 - Part of 6
    • 14.2MM, 9/16 (Qty: x2)
  • 14 - Rad Inl Hose Eng
    • 42MM (Qty: x1)
  • 16 - Rad Inl Hose Rad
    • 42MM (Qty: x1))
  • 17 - Rad Surge Tk Inl Hose
    • 1/2 - 13/16 (Qty: x2)
  • 20 - Throt Body Htr Otlt Hose
    • M16X1 (Qty: x1)
  • 22 - Rad Otlt Hose Rad
    • 42MM (Qty: x1)
  • 24 - Rad Otlt Hose Eng
    • 43.5MM TO 53.00MM (Qty: x1)
  • 27 - Rad Surge Tk Otlt Hose
    • 25-29MM (Qty: x2)
Old Aug 4, 2021 | 09:30 PM
Smoken1's Avatar
Smoken1
Did you already buy the hoses? If not here are all the Gates part #'s
Old Aug 5, 2021 | 11:04 AM
leadfoot4's Avatar
leadfoot4
  • 7 - Part of 6
    • 42MM (Qty: x1)
    • 42MM (Qty: x1))
    • M16X1 (Qty: x1)
    • 42MM (Qty: x1)
    • 25-29MM (Qty: x2)
Sorry I can't help you, as I installed them a long time ago, and didn't keep the sales receipt, which had the part numbers..... IIRC, I purchased them from Jegs.
Old Aug 6, 2021 | 12:33 AM
herwawan's Avatar
herwawan
No worries - thanks for chiming in though I’ll check Jegs. I’m going on, wish me luck haha
https://www.jegs.com/p/Gates/Gates-P...43359/10002/-1
Yes! I saw that post - I actually tried to go that route, but most parts were not readily available and I need to get to work ASAP!
Old Aug 6, 2021 | 08:05 AM
herwawan's Avatar
herwawan
Hell yeah, progress. Everything's on the forum, just gotta dig deep enough! Thanks to this thread:
Upper Rad is 1-1/4
Lower Rad is 1-1/4 and 1-1/2
Heater hoses are 5/8
Overflow to Rad is 3/8
Overflow to block is 9/16
Valve cover to TB is 3/8
TB coolant (usually bypassed depending on mod or not) 3/8
Drivers side Air hose is 3/4
Now, I have a big problem haha I only know the metric system, and this inch system makes no sense to me. Tried to look through this chart:
https://www.bearing-king.co.uk/inch-...sion-chart.pdf
But really, it's a complete mindf*ck for me since nothing relates to anything. If anyone can help, it'll be greatly appreciated. Spent so much time on this with little progress 🤣
Old Aug 6, 2021 | 10:05 AM
ArmchairArchitect's Avatar
ArmchairArchitect
Banned Scam/Spammer
From: Philadelphia PA (Birthplace of the USA, UNESCO World Heritage City)
You can type the inches in here and it will tell you the metric conversion:
https://www.google.com/search?q=inch...4dUDCA4&uact=5
Old Aug 6, 2021 | 01:12 PM
leadfoot4's Avatar
leadfoot4
Gates # Size Nom. Hose ID Fits Hose OD 32915 SB15 1/4" 1/2" to 11/16" 32919 SB19 3/8" 11/16" to 13/16" 32922 SB22 1/2" 13/16" to 15/16" 32925 SB25 5/8" 15/16" to 1-1/16" 32929 SB29 3/4" 1-1/16" to 1-3/16" 32932 SB32 7/8" 1-3/16" to 1-5/16" 32934 SB34 1" 1-5/16" to 1-1/2" 32941 SB41 1-1/4" 1-1/2" to 1-3/4" 32948 SB48 1-1/2" 1-3/4" to 2" 32954 SB54 1-3/4" 2" to 2-1/4" 32960 SB60 2" 2-1/4" to 2-1/2" 32967 SB67 2-1/4" 2-1/2" to 2-3/4" 32973 SB73 2-1/2" 2-3/4" to 3" 3 2979 SB79 2-3/4" 3" to 3-1/4" 32986 SB86 3" 3-1/4" to 3-1/2" 32990 SB90 3-1/8" 3-1/2" to 3-5/8"
This was supposed to be a cut and paste of the above numbers, in a chart form, from the verociousmotorsports.com site, but this is how it looked, when I pasted it here....
Old May 25, 2026 | 12:02 PM
cosaren's Avatar
cosaren
Hi,
  • Radiator Hose Kit Silicone
Now the problem is that I most likely cannot use the regular clamp on these hoses, because of the material difference. I am having a hard time finding the size of the hoses, and I don't have much experience with silicone. For reference I have been looking at VW Audi Silicone Hoses as a guide since they share similar sizing and clamping requirements which might help narrow things down. I'm looking for info on the following hoses:
9:01 PMClaude responded: Avoid standard worm drive clamps on silicone hoses as they can cut into the material.Avoid standard worm drive clamps on silicone hoses as they can cut into the material. Use constant tension clamps or T-bolt clamps instead as they distribute pressure evenly without over-tightening. For hose sizes on the 02 C5, upper and lower radiator hoses are typically 1.5 to 1.75 inch diameter, throttle body and heater core hoses around 0.75 to 1 inch, and surge tank hoses usually 0.75 inch. Always measure your specific connection points before fitting. When installing, use coolant or soapy water to slide hoses onto fittings, allow extra length when cutting, check connections for corrosion beforehand, and bleed the cooling system thoroughly after reassembly to avoid air pockets.
Old Jun 2, 2026 | 09:01 AM
TheBac's Avatar
TheBac
I would sure hope it didnt take five years for the guy to replace all his hoses.
Old Yesterday | 09:42 PM
redzg's Avatar
redzg
Aren’t the factory constant tension clamps the most appropriate for the softer material of the silicone?
To Silicone hoses - what clamps?
