For Those Who Installed a Rear Camera...
Received 2,690 Likes
2018 C5 of Year Finalist
....I'm curious where you mounted the camera. I already have a double din system in place in my 2004 convertible and I'm considering upgrading my current head unit and speakers so while I'm in there I might as well add the camera but I want it to be stealth and well positioned. Pics are appreciated!
2023 C5 of the Year Winner - Unmodified
Camera mounted in my previous C5 centered above the plate. Just make sure you ground it properly.
MSG C5 (04-30-2024)
Received 3,206 Likes
St. Jude Donor '20-'21-'22-'23
I have a crappy license plate camera. I want to upgrade.
I saw this and fell in love, but don't know what camera was used:
I've seen these before as well but not sure if I would want the camera disrupting the high brake light when engaged. Is that camera drilled and wired through the high brake light? I like the one near the top of the license plate as long as it's stealth as some I've seen are more rectangular than round. Similar to the C7 front grill cameras. Is there a visibility benefit in mounting it higher vs. lower?
Just installed mine earlier this month. I didn't have a license plate frame on my car, so I bought a license plate frame camera. Very easy install and it was pretty cheap on Amazon.
A3lseeker (05-02-2024)
Tusc (05-06-2024)
Night Owl for life
Received 3,296 Likes
Can you spot it?
Tusc (05-06-2024)
Night Owl for life
It gets power/ground from the source. You just need to tap into the positive backup lamp wire to activate the camera's screen backup grid lines
I know most head units (if not all) have you wire into the reverse lamp wire harness to cause them to switch to camera mode. My Kenwood also lowers the sound volume slightly.
The Kenwood I have has a button that can activate and leave the camera on at will.
MSG C5 (05-01-2024)
When the camera is powered the display gives it priority.
Tap seen below on right
MSG C5 (05-01-2024)
Thanks. Do you know your Kenwood head unit model number? I know they change every year but looking to comparison shop as my current head unit is a Kenwood.
MSG C5 (05-01-2024)
Night Owl for life
it's all done automatically, no need to press anything.
Night Owl for life
here's more info: https://www.corvetteforum.com/forums...post1606335501
if you have any other questions, feel free to ask.
BTW i've said it before and saying it again...the rear view mirror camera is awesome and the best way to do it. many of the newest high end cars have this feature including the C8.
Night Owl for life
^yes it is reflective...or just take it off!
A3lseeker (05-03-2024)
