Hi, I have seen that around 2016 there were alot of problems getting the Navtool systems. So they don’t look good at the BBB.
My question is -is anyone still having problems getting the system or is there still problems after that episode?
Am also wondering if it turns on the camera automatic when your speed is 10
mph or lower or do you have to use reverse first? I have seen both ways said so not sure.
Any advice on them or the front camera system is greatly appreciated.
I ordered mine last summer and had an excellent experience. It took awhile for my tracking to show up and customer service can be tricky with the language barrier. But everything came as described and install was pretty straight forward with the help of some YouTube videos. The system has worked flawlessly since then. Mine is a 2014 and I didn't add cameras so I can't speak on that.
thanks bluegrassmotorsport for the answer. Looks like no one else wants to comment. I appreciate your time.
Mine has been installed for roughly 3 years and has the front camera on when under 10 mph automatically I guess. System has worked great since day one.
thank you, sounds like no problem with them getting it to you either. Appreciate it.
