C8 General Discussion The place to discuss the next generation of Corvette.
Sponsored by: Wheel Design
LS6 gets 8% more volume and only 8% more HP?
Old Mar 24, 2026 | 08:04 PM
imxz28's Avatar
imxz28
Default LS6 gets 8% more volume and only 8% more HP?
Could GM have released bogus performance numbers at the Vegas Dealers meetings? I just got to thinking - LS6 gets 8% more volume and only 8% more HP? What about all the other tricks they have pulled off? Bigger cam, better fueling and other things have to account for something more... Are we in for a 550hp or even a 560hp surprise? Or is 8% more to net 8% more a fair assessment?
Old Mar 24, 2026 | 08:19 PM
Cjunkie's Avatar
Cjunkie
Is the compression staying the same or going down? Will this engine have a smaller camshaft? Will it have stricter emissions?
There are SO many variables besides displacement.
Old Mar 25, 2026 | 01:48 PM
EvanZR1's Avatar
EvanZR1
C4 of Year Winner (performance mods) 2019
Obviously, nothing is truly set until GM does their official announcement, but I feel like a 40HP jump is pretty good. Keep in mind the recent HP jumps have been:
LS1-LS2: 50HP (2005) change from 5.7L to 6.0L
LS2-LS3: 36HP (2008) change from 6.0L to 6.2L
LS3-LT1: 24HP (2014) change to direct injection, still 6.2L
LT1-LT2: 35HP (2020)
So jumping by 40HP from the LT2 to the LS6 will be the biggest jump for the base engine Corvette since 2005. I'm honestly surprised sometimes that they keep squeezing more HP out over the years, especially getting another 35HP out of the LT2 which is the same displacement and DI as the LT1. It really feels like GM is at the point of not having much more they can optimize, so gains from just straight displacement increase make sense.
Old Mar 25, 2026 | 03:09 PM
PacerX's Avatar
PacerX
Have to disagree...
Anything under 550hp is lame, regardless of the past.
The new 6.6 in the trucks is rumored to jump from today's 6.2 @ 420hp to 475hp, in an application that REALLY prioritizes low end grunt.
EDIT: The 6.6 L8T is 401hp. The 6.6 L8P is 523hp. The difference? GM basically stabbed a cam in the L8T and called it a day. A new 6.6 Corvette motor should bury an L8P.
Old Mar 25, 2026 | 03:59 PM
Kappa's Avatar
Kappa
Why is this in the ZR1 section?
Old Mar 25, 2026 | 10:41 PM
snork's Avatar
snork
anything 500hp and greater your average owner will see substantial increase in insurance premiums, some will be denied insurance
Old Mar 25, 2026 | 10:53 PM
PRE-Z06's Avatar
PRE-Z06
The more cubic inches you have to feed, the harder it is to maintain the same volumetric efficiency as an engine is essentially an air pump. A bigger cam is the easy button to power increase as seen on the 523hp 6.6L crate engine, but it’s 218/231 duration isn’t passing emissions as that’s more duration than what came in the larger 7.0L LS7 of 20 years ago with looser emissions.
Old Mar 25, 2026 | 11:12 PM
FAUEE's Avatar
FAUEE
GM could squeeze 550hp out of a motor this size easily. But they won't, they have no need to because they have nobody competing against them. 530hp will satisfy the "need a reason to upgrade" crowd, beats Mustang GT in HP, and gives them plenty of room to have some motors that make more power from variation to not get sued.
As much as I think having it make 550hp is the right call, I also recognize they will not, and will instead probably offer a "hot cam" from GMPP that makes 550hp or more. And if you install that, you get no warranty, so it's a win-win for them.
Old Mar 25, 2026 | 11:31 PM
LS1LT1's Avatar
LS1LT1
All true/solid points. But the jump from LS2 to LS3 was actually 30hp. Yes, it was 36hp with the optional NPP exhaust though (which was not available with the 2005 - 2007 LS2 cars).
Old Mar 25, 2026 | 11:37 PM
PRE-Z06's Avatar
PRE-Z06
Originally Posted by PacerX
Have to disagree...
I don’t think an OE LT2 cam in a L8T would make 500hp as the rule of thumb is 2hp/1* of intake duration. Keep in mind the L8T is tuned for 87 octane and the L8P is tuned for premium, so that’s part of the difference as well.
The LT2 already makes more than the Mustang GT?
Old Mar 25, 2026 | 11:38 PM
LS1LT1's Avatar
LS1LT1
I think we might still get a little surprise with the final LS6 power ratings as well. Not quite 550hp, but possibly 540hp in the Grand Sport (standard NPP exhaust?) and 535hp in the Stingray without NPP exhaust?
But the big story will also be the torque numbers. If it’s in the 510 - 515 range, you will feel that.
Old Mar 25, 2026 | 11:42 PM
FAUEE's Avatar
FAUEE
That's fair I thought the GT and dark horse made the same 500hp.
Either way that means the C8 would make more hp than Dark horse with 530hp. GM can claim "best in class horsepower" with impunity. Except charger makes 550hp from its turbo I6. Let's not talk about that lest GM think that's what we want and send their trolls out to defend not offering a V8 and only doing a turbo I6 as "the future" and that wanting a V8 makes you a Luddite or any of the other crap the anti manual crowd says.
Old Mar 26, 2026 | 12:58 AM
hawkgfr's Avatar
hawkgfr
It'd really be no comparison to the mustang engine imo....302 to 409 CI.... And now the Dark horse will come with a supercharger at about 800 hp.. if you want... so there goes that impunity... oops... Now matter how you slice it they get all they can get out of the little motor..I personally prefer the low end grunt more cubes provide.
To be fair..I may swing for the c8 with the new engine...that may be enough to move me to jump in..
Old Mar 26, 2026 | 01:03 AM
Ltngdrvr's Avatar
Ltngdrvr
495 HP from a 6.2L engine is right at 80 HP per liter, so a .5 liter displacement increase would give the new 6.7 engine 40 HP bump for the 535 HP being talked about.
But, that is without any other efficiency changes.
So, yes, it very well could be they are blowing smoke.
It could also be that they are being conservative until final development is done, and the numbers could change by the time they go into production.
I predicted 550 HP quite a while back during a similar discussion, it's a nice round power number, and sounds way more impressive than 535 HP.
But, they will not allow it to make more HP, combined with the electric front drive X motor, than the Z06 makes, so they will have to bump the Z06 up too, so they may be waiting until they get all the engine power numbers nailed down.
Old Mar 26, 2026 | 06:14 AM
BuckySti's Avatar
BuckySti
Yes, but the new engine horsepower rating will start with a 5 Instead of a 4, so it’s way more. .
people either think that way, or marketers think people think that way. If somebody wants to sell their house for $500,000, they listed for $499,999. makes me wonder if that’s why the original C8 was 495 HP, so the next jump would look more appealing.
Old Mar 26, 2026 | 08:21 AM
PRE-Z06's Avatar
PRE-Z06
Gotcha, personally I didn’t think people cross shop the Corvette and pony cars though I suppose with the Camaro being discontinued and the prices not far off maybe they do. Though the Corvette is lighter and more aero dynamic, so it’s still faster than the Mustang or Challenger.
I will say I actually prefer the Hurricane engine over the Hemi in my Ram as it’s lowend torque is better for towing, though that’s not the powerband want for a sports car as I like a more linear torque curve on the track.
Old Mar 26, 2026 | 01:32 PM
LS1LT1's Avatar
LS1LT1
I was close, glad that my prediction fell 5tq shy though.
To LS6 gets 8% more volume and only 8% more HP?
Old Mar 26, 2026 | 02:35 PM
PRE-Z06's Avatar
PRE-Z06
Not only is it a 50ftlb increase, but the Z06 gearing adds another 7% more torque multiplication over Z51 or 12% over base model!
Old Mar 26, 2026 | 03:31 PM
Ltngdrvr's Avatar
Ltngdrvr
I am disappointed in the final numbers on this new LS6.
Seems to me like just the displacement increase alone should have given the 40 HP bump, throw in the added comp ratio and new intake tuning and you would think that 550 HP would have been the number.
But, after listening to the engineers and others discuss the engine particulars, they did not build for HP, they built for torque.
Smaller high velocity intake ports and manifold runners make torque, but limit top horsepower.
Old Mar 26, 2026 | 04:45 PM
PRE-Z06's Avatar
PRE-Z06
The displacement increase is only from an increased stroke, so why would you expect it to increase hp? Look at increase in power across the rev range though, definitely a seat of the pants increase!
