J56 Components - Road Racing
Been a long time since I've been on this forum, but I'm back. I have now a 1974 coupe that is an Historic Road Racing car, built to resemble what a 1974 Corvette might have looked like if it were run by an amateur like me
. My question is regarding the J50/J56 braking options. The category of road racing the car is built for (called Group S here in Australia) only permits factory fitted braking componentry, meaning I need to use the stock brake calipers and disc size. We are permitted to use drilled/slotted rotors, and also to put tandem master cylinders on. The previous owner installed the pictured tandem master cylinder, and removed the booster, but the braking performance is woeful at best; I couldn't lock the wheels if I tried.Given the car is a historic racing car and supposed to be a representation of cars of the period, and I am enthusiastic about keeping things as period as possible, I want to change the car so that it has all the components of a car fitted with the J56 option. I have done some research on here and found a lot of useful information about the J56 option, specifically the calipers with the dual pin pad locking system, as well as a different proportioning valve arrangement, but cannot really find a definitive list of what would be fitted? I will most likely going to buy the parts needed to make the current calipers suitable for J56 pads (machine off the standard retaining boss and drill the pin holes, and replace the pistons with titanium), and am happy to run parts available on models earlier, such as a 1969 L88.
I also am seeking advice on whether or not everyone thnks I should fit the J50 power brake option back to the car. Does anyone have any advice on what would have been most likely in period, most specifically what an L88 would have campaigned at LeMans or Daytona? Would they have run power brakes?
Thanks in advance.
This is a current listing here on the forum in Parts for sale. This is a good deal.
https://www.corvetteforum.com/forums...-brackets.html
Bill
From what I've read on this forum the factory manual brakes are sufficient on these cars, if your calipers and rotors are stock but the master cylinder(s) aren't I would look into that as well.
The factory manual brake cars have a different horizontal center line for the master cylinder, I believe it's raised, to give more leverage from the pedal.
The backing plates of the original J-56 pads were made from Inconel. These can be distinguished from steel repops as the Inconel ones are non-magnetic. Porterfield Brake will reline them with several pad material options.
Regarding the pistons, my understanding is the J56 factory pistons are aluminum with a phenolic insulator. There are differences between the 1st design calipers and the later ones.
J56 calipers are mainly stock Delco calipers with the top bosses milled off and the two pin mounting holes drilled in the calipers. The two pins help keep the pads from moving around, but the main advantage to the J56 calipers were the insulated pistons. Besides the calipers, J56 also included a proportioning valve and the bracket stiffeners. While the standard master cylinder used on 67 Corvettes had a 1" cylinder bore the 67 J56 cars came with a 1 1/8" bore, the same as 68 up power brake Corvettes.
Here in the US, the SVRA (Sportscar Vintage Racing Association) is largest vintage organization. Corvettes built after 1972 race in SVRA Group 10, which allows for a lot more in the way of modifications. Brakes are free in Group 10, but Group 10 is a tough glass to race a full frame Corvette in because it includes tube frame/fiberglass body silhouette racers (80's Trans Am & IMSA GTO Camaros, Mustangs, Merkurs, etc) NASCAR stock cars (and trucks through the early 2000's0, Porsche 930, 924 GTR, 944 Turbo, and so on, FIA Group 4 & 5 cars and others. Fortunately some of the smaller and regional vintage organizations do allow Corvettes, Camaros etc through about 1979 to compete as long as they comply with the rules in the 1972 SCCA GCR.
Here are a couple pictures of our relocated front calipers and the spacers we use in them.
Last edited by gbvette62; Mar 29, 2026 at 05:36 PM. Reason: corrected a year quoted
I guess I should have mentioned above that there are two different sets of J56 stiffening brackets, 65-68 and 69-75. The 65-68's are casting numbers 3882783 (LH) & 3882784 (RH), and casting numbers 3948879 (LH) & 3948880 (RH) are 69-75's. The difference between the two sets is mainly the size holes, if my fading memory is working properly two of the three holes are smaller on the earlier brackets? The 65-68's are a little harder to find too.
I also just noticed that I mistakenly said 70 up power brake master cylinders were 1 1/8" bore, but it's actually 68 up, and I've corrected it.
Are you allowed to pick and choose parts from any year of C3 production? I only ask because you have an 80-82 bumper. That's certainly the best stock option for your car, so hopefully it is allowed.
@gbvette62 It is my understanding that the proportioning valve was dropped for the 69 model year.
US organizations do allow the addition of a front air dam to most cars as long as it's width is no more than around 58"-59" wide.
I am not permitted to relocate the calipers unfortunately, so I'm stuck with the hard to route ducting. It certainly sounds like with your optimized setup on standard components you are getting some serious and reliable stopping power. I am definitely keen on retaining the factory master cylinder, I think the aftermarket master detracts from the under bonnet appearance.
Sounds like your 1972 GCR is quite similar to our local rules. Our touring cars are permitted more freedoms as far as component modification and replacement (can use any factory caliper from any touring car produced up to 1972, most use Volvo 4-piston). Sports cars are quite hamstrung, which is just another reason to love Corvette because there was so much performance stuff built in and available in period.
By your description, if I put the most suitable pistons in my calipers, milled off the top boss and drilled the J56 style holes for pad retention, I'd have J56 calipers essentially? This is probably my preferred option.
That's my understanding, Chevrolet dropped it after 68, but it was originally part of the option. Of course an interior controlled brake proportioning valve or brake bias control is always a good idea for any dedicated track or race car.
Thank you all for your responses, I am blown away with the information you have provided. I look forward to pooling our knowledge and coming up with a solution that will bring out the best Corvette had to offer.
So far we have:
- J56 calipers being factory-modified factory Delco items, with the central pad locating boss milled off, and replaced with two holes drilled at each end to prevent pad movement.
- These calipers were fitted with different pistons designed to inhibit the transfer of heat due to the additional braking load.
- Pre-'68 models had a different proportioning valve fitted. Cars post-'68 did away with the valve.
- All cars had caliper bracket stiffeners fitted, with pre-'67 having smaller mounting holes to the later models.
- J56 could be fitted to both power and non-power brake cars.
The backing plates come up from time to time on this forum (and eBay) but caution is advised as the true Inconel material plates are rare. Porterfield Racing Brakes in California will reline them (I just had mine done).
If my quickly fading memory is correct, Jim's been using Hawk pads on the red Corvette above, and all his other Corvette and Camaro race cars too. Next time I talk to him (which is somewhat regularly) I'll ask what pads he's using and their part number(s) and post them here or PM them to you.
The red 65 above of is using pistons that were developed by a gentleman from Massachusetts (US) with input from Lonestar Caliper, at least that's what I know were previously being used in it. I live about 3 hours from Jim, the owner/builder/driver of the car and usually only work on it at race tracks, but to my knowledge we're still using those pistons. You could email Ken at Lonestar (he's Lonestar's owner) and ask him about the pistons. Tell him you were looking for information about the caliper pistons developed by the man in Massachusetts and used by Jim Glass in his race car. Ken should also have some of the stiffening brackets too, I'm sure he at least has the cast iron ones. His email is ken@lonestarcaliper.com
There are a some exceptions allowed for brake upgrades in some of the production car classes. 53-64 Corvettes are allowed to replace the original drum brakes with 65-82 Corvette disc brakes, but this is allowed more as a safety upgrade.
You may also want to reach out to Jim Glass, the owner of the red 65 racer above. He can probably tell you more about the pistons in his calipers and I think he may have some of the cast iron caliper stiffeners he'll sell. You can tell Jim you were talking with me, Glenn Brown, his email is jimglasscorvette@gmail.com . Here's a link to his website so you can get a look his shop, the red 65, and some of the other race cars he has and ones he previously had. https://www.jimglasscorvette.com/
Thanks in advance.
I have sold 3 sets to a guy that road race America in his 73 or 74 car like yiurs
he said repop piston don’t last and wear out after one race
i may have some repop original style J56 calipers
i may have an original NOS J56 calipers for your car
casting is 547
i have spares of J56 dual pin pads but worn out, you would need to have them refurbished
some maybe conical metallic but I have to check
pm me and go from there
Thanks
grant
The key to the j56 is heat control. The curved pad backing plates are expensive inconel IIRC, and worth it to reduce heat transfer. The std I OEM aluminium pistons are horrible on track and any ceramic phenolic titanium you can find is an improvement. I would even make and add some titanium pad backing plates if needed. That transfers little heat. The std aluminum piston setup will easily boil the fluid on track use, it transfers way to much heat. I would check with Duntov Racing and get recommendations from them, and/or titanium pistons.
If you convert from p brakes to std make sure you make all the pedal and mc bore size changes. It is very likely whoever converted it did not do that and that is why you cannot lock the brakes. C3 manual brakes have excellent feel. The pedal throw is a little longer. The MC bore size is 1-1/8" for PB and 1.0" for MB. The linkage on the clutch pedal must also be moved (up) to the upper hole to get more pedal leverage. That is what makes the center of the MC move up a little. IIWM I would keep the tandem MC and make it in-car adjustable. You want all 4 tires to lock at the same time, and that varies with fuel weight on board. Ditto for an adjustable rear sway bar, in-car, if allowed.
Regards,
Stan Falenski
Here if the old rule books didn't allow a modification back them, we're not allowed to make it now. We're not even allowed to use Wilwood's D8-4 Corvette replacement calipers because they're aluminum, not cast iron (there is one race organization here that allows the Wilwood's, and other organizations will usually make a one time exception if an entrant with Wilwood"s isn't a regular participant).
That is what GM did, they didn't have a unique or special caliper casting for the hand full of J56 calipers they sold. The casting numbers for J56 and standard calipers are the same.
On Corvettes with non J56 the brake lines came from the master down to a brass distribution block that sent brake fluid to the front and rear brakes. This brass block also contained the switch for the "Brake" warning light on the dash. People often confuse the brass distribution block used on 67 up Corvettes calling it a proportioning valve, but it is strictly a distribution block and housing for the warning light switch. Early J56 cars had an actual proportioning valve installed in the brake lines between the master cylinder and distribution block, directly under the master cylinder.
All 67 Corvettes except those with J56, and all 68-76 Corvettes with manual unassisted brakes used a dual reservoir master cylinder with a 1" bore. 68-76 Corvettes with power brakes and 67's with J56 used a dual reservoir master with a 1 1/8" bore (77-82 Corvettes came standard with power brakes and 1 1/8" bore master).
So we have some extra things to add to the list now:
- These calipers were fitted with different pistons/insulators designed to inhibit the transfer of heat due to the additional braking load.
- Master cylinders, regardless of J56 option: PWR - 1 1/8" and STD - 1"
- J56 pads had an inconel backing plate.
