Headlight Motor brushing
Old Apr 2, 2026 | 12:20 PM
BET VETTE's Avatar
BET VETTE
Default Headlight Motor brushing
Have anyone used the metal sprockets for the pop up headlights
Old Apr 2, 2026 | 01:09 PM
jv9999's Avatar
jv9999
Old Apr 2, 2026 | 06:16 PM
Natty C's Avatar
Natty C
2022 C4 of the Year Finalist - Unmodified
2021 C4 of the Year - Unmodified Finalist
I'd considerd them but then I got to thinking that they were likely originally made from vinyl for good reason. That likely being so that the gear itself breaks apart before anything else it comes into contact with through operation tears up. A metal gear might have the opposite effect and tear up whatever it comes into contact with through operation.
That's my theory anyway.
Old Apr 2, 2026 | 06:28 PM
BET VETTE's Avatar
BET VETTE
Good point
Old Apr 2, 2026 | 06:44 PM
Natty C's Avatar
Natty C
Originally Posted by BET VETTE
Good point
I used to own an '84 Ford Thunderbird that was souped up. Well, actually all that was done was suspension work and wide tires and American Racing rims on it.
But that was one sweet looking ''Muscle'' type of car. That work changed it's entire look and stance. It had a 302 in it. Pretty much mint condition, inside and out too. Gray velour interior, nice silver paint and power everything. I loved that car. Wish I had soem pictures of it. I may have some on some old, undeveloped film, but I dunno where I could even get it developed.
Anyway,all of that rambling aside, the timing gear crumbled away on it. It was vinyl.
So that's where I developed that theory mentioned above.
Old Apr 2, 2026 | 09:41 PM
IHBD's Avatar
IHBD
Pro Mechanic
I've renewed a bunch of motor assemblies by replacing the pellets. Because the big gear is installed in the housing with the pellets down, the big gear must be removed. Because the big gear has a depression in the middle that the motor's worm gear drives, the big gear doesn't just 'pull out' without first removing the motor shaft and drive gear unless you force (pry) it up and out. This probably damages the gear, and perhaps that's why it fails in the future and is replaced with a metal gear "because the plastic gears broke or stripped."
I'm pretty sure the assemblies I've worked on were virgins in that they had not been "had" by previous bubba's prying out the big gear, so the gears I've encountered were A-Ok, and I reused them.
Removing the armature and drive gear is easy. Putting it back together is not so easy because you have to retract the brushes into their holders to install the cover plate that holds the brush assemblies. I tie the brushes back with dental floss. With the cover almost all the way seated, cut the floss, pull it out and install the two motor bolts.
Old Apr 4, 2026 | 02:01 AM
Natty C's Avatar
Natty C
Originally Posted by IHBD
Putting it back together is not so easy because you have to retract the brushes into their holders to install the cover plate that holds the brush assemblies..
Holy moly, you sure aren't kidding about that.
That part of the job was a giant pain in the rear end when I did mine.
I needed four hands and only had two. lol.
After about an hour of fiddling around with it I had my son help me out with extra hands. Didn't even consider stopping to think about any kind of workaround like you did with yours. i just yelled, ''hey, comere for a minute.'' And it still took a few times to get it. But the second one went much quicker once we got the first one out of the way.
The power window motors are basically the same way; same setup.
Old Apr 4, 2026 | 02:25 AM
prinzSD455's Avatar
prinzSD455
Finalist 2020 C4 of the Year - Unmodified
I replaced mine with the plastic ones
Old Apr 4, 2026 | 02:28 AM
prinzSD455's Avatar
prinzSD455
I will remember this the next time I have to replace thee gear again. I did mine about 15 years ago.
Old Apr 4, 2026 | 02:12 PM
IHBD's Avatar
IHBD
Pro Mechanic
you have to retract the brushes....I tie the brushes back with dental floss.
I also only have two hands. This comment made me think about how I "tie the brushes back".
Select a socket that the O.D. will almost, (but not force) the brushes into their fully-retracted position and place the socket between the brushes. Put the dental floss through both braided brush leads, tension it gently and tie it together on top of the end cover. Remove the socket and check that the brushes are still far enough apart to fit over the commutator. Install the cover, cut the floss, install the bolts. Cheers.
Old Jun 10, 2026 | 05:56 PM
BET VETTE's Avatar
BET VETTE
A nice bench vise should help
Old Jun 11, 2026 | 05:19 PM
steve40th's Avatar
steve40th
St. Jude Donor '03 & '05
When I changed to glass housings and OSRAM bulbs, I did change to the bronze gears. Been there since 1999, still working.
Old Yesterday | 04:43 PM
BET VETTE's Avatar
BET VETTE
It could’ve been because it cheaper to produce for the masses
Old Today | 09:12 AM
Impala Balko's Avatar
Impala Balko
From what I understand the bronze gear is a waste of money because the real wear item is almost always the plastic pellets. When i pulled mine apart the gears were fine but the plastic pellets had turned into dust.
Old Today | 09:40 AM
steve40th's Avatar
steve40th
If anything, upgrade to a little better plastic than nylon. Delrin will likely never break.. If you can find or even cut it.
https://www.corvetteforum.com/forums...r-plastic.html
Old Today | 09:58 AM
BET VETTE's Avatar
BET VETTE
Theses prices are good so it might be better to buy the set
To Headlight Motor brushing
