Sponsored by: CARiD
Cooling Engine Compartment
Old May 3, 2026 | 10:31 AM
Ramets's Avatar
Ramets
Default Cooling Engine Compartment
Has anyone tried those under body cooling fin thingys that direct air up into the engine bay? Do they work?
Old May 3, 2026 | 11:51 AM
patton's Avatar
patton
St. Jude Donor '09
Is your car running too hot ?
Old May 3, 2026 | 11:59 AM
Ramets's Avatar
Ramets
Not yet, but I'm going on a long road trip this summer and will be in places that will be over 100 degrees.
Old May 3, 2026 | 12:28 PM
patton's Avatar
patton
St. Jude Donor '09
I do not have them on my 25 e with 8 k on it as i have never seen over 200 degrees in panhandle florida traffic or highway . From what little I have read they do work/needed on European cars because of their special exhaust systems ....... car makers test pretty much extreme tempertures
Old May 3, 2026 | 12:53 PM
Ramets's Avatar
Ramets
I saw a test on YouTube where it didn't have much effect on coolant temps., but did reduce the oil temp by 10 degrees.
Old May 3, 2026 | 02:02 PM
c5racr1's Avatar
c5racr1
It's mostly for engine bay temp. If you want to add them, add them.
Old May 4, 2026 | 05:24 AM
RDMISTC8's Avatar
RDMISTC8
I put them on my 2024 Stingray and noticed absolutly no difference in coolant or oil temps. In dact Josh Holder when asked the question on Corvette Today Podcast this week said there is absolutly no benefit to them unless you have a european c8 with the particulate filter.
Old May 4, 2026 | 07:30 AM
c5racr1's Avatar
c5racr1
you would have to look at the engine bay temp sensor to see if it is making a difference, not the oil or coolant sensors.
Old May 4, 2026 | 07:51 AM
tobaccokid's Avatar
tobaccokid
Have them on both my Z06 and ZR1. Cannot beat additional cooling no matter the effectiveness level - simply put, more is better.
Old May 4, 2026 | 08:20 AM
RDMISTC8's Avatar
RDMISTC8
Absolutly, just saying these guys that claim 40-50 degree drops are most likely exagerating a bit. If it made that much difference gm would put them on every c8. Like I said I have them, spent the money for the GM parts and will remove them and add them to my Grand Sport when the time comes.
Old May 4, 2026 | 08:21 AM
chevyrules727's Avatar
chevyrules727
2024 C8 of the Year Winner - Unmodified
They are on the european models to cool the gas particulate filters that are on their exhaust system. Since US models don't have them, we don't get the air reflectors. They have zero effect on cooling the engine.
It does have an effect on cooling the engine compartment.
Old May 4, 2026 | 08:22 AM
RDMISTC8's Avatar
RDMISTC8
Yes, but if the coolant and oil temps are unchanged any drop in engine bay temps would be of little consequence.
Old May 4, 2026 | 08:24 AM
c5racr1's Avatar
c5racr1
I could see a temp drop in that range IF you look at the correct sensor. NOT the oil temp or coolant sensor, The engine bay temp sensor is the one to look at. also lowering the bay temp sensor will help with IAT temps, which directly effect performance.
Old May 4, 2026 | 08:30 AM
RDMISTC8's Avatar
RDMISTC8
Like I said I have them and will have them as long as I have a C8 but for street driving I dont see any difference with or without them. I dont track my car so maybe a difference there but You would think if there was any substantial increase they would be on every C8 or at least ZR1's.
Old May 4, 2026 | 08:34 AM
c5racr1's Avatar
c5racr1
I track mine frequently and there is a difference.
Old May 4, 2026 | 09:47 AM
itsonlyairandfuel's Avatar
itsonlyairandfuel
In testing at 100F ambient, after running 10 miles and pulling off the interstate. Then waiting for heat soak to push oil water and transmission to 205-208 degrees while stopped. The temps then fell to 170-175 for all 3 temps in about 3miles at 75mph. Then guess what, the thermostats closed and pushed temps to about 185F just like it would in cold climates. This is why some may not understand, and think what they do. The results are with the diy germany ducts that I built. Different products the results may vary.
Old May 4, 2026 | 02:52 PM
Andybump's Avatar
Andybump
It may be useful to consider where the ambient air temperature sensor (aka engine compartment air temperature sensor) is located. Attached is an illustration showing where it is - taken from the "Ambient Air Temperature Gauge Sensor Replacement (Engine Compartment Air Temperature) - Removal Procedure" in my 2020 version of Service Manual for SR. The same procedure in the 2024 LEMON manual shows in a slightly different postion - do not know why. I attached that too.
Both say:
"Engine Compartment Air Temperature Sensor
Operating Conditions: Engine = Idling - At normal operating temperature.
Parameter Normal Range: 100to 150°F"
It has key role in determine when the engine compartment cooling fans come on, and at what speed.
To Cooling Engine Compartment
Old May 5, 2026 | 03:17 AM
Jacques Albrecht's Avatar
Jacques Albrecht
Some time ago I bought & easly installed your very well made aluminium alloy undercarriage air scoops. Couldn't be happier with that early decision. Now they can be had from many on-line sources and some are even offered in plastic too!!
Your design & custom manufactoring is perfect for these. THX
Old May 5, 2026 | 05:16 AM
superramvette2's Avatar
superramvette2
They for sure lower engine bay temperatures as verified by the OEM engine compartment sensors readings. I tested itsonlyairandfuel's version and saw a decrease in engine bay temperatures within a couple miles of driving. If you have extra engine bay heat like I do due to headers, cat deletes without coating, etc or maybe a supercharger this could potentially help keep temperatures down . I also have a carbon fiber hatch. Carbon fiber doesnt really love lots of heat so extra airflow can keep my investment from breaking down. (vent areas show signs of heat damage already)
I wouldnt count on lowering actual engine temperatures but mainly exhaust component and engine bay/ rear trunk temps. It's a personalized decision and for some, benefits may outweigh any downsides such as extra dirt in engine bay (more air= more dirt) or potential for some extra drag from below the car.
Old May 5, 2026 | 07:03 AM
Mark9's Avatar
Mark9
I have a set of OEM version ones installed as well as the VO9 radiator as my oil temps were getting out of hand on the track (240+). A set of non-oem style installed last season had no effect (without the additional radiator). Oil temps were consistenly 15+ degrees higher than coolant temps without the additional radiator. This season, thus far, has shown oil temps no higher than 5 degrees higher than coolant temps after a lengthy session on the track. Coolant temps are also lower. On the street, oil temps are 25-30 degrees lower than coolant temps where prior they were essentially in sync with each other. If folks want or need to keep their oil temps in control, the V09 mod is the way to go. I used all OEM parts for the install.
