Quadrajet fuel leak
Popular Reply
Typical forward plug leak: Fuel dripping from the forward fuel inlet bowl plug:
Carb disassembled and ready for repair of the forward plug:
Plug retaining swage ground down and removed:
Drilling pilot hole thorugh the front plug
Tap-drill sized drill going into the plug, which pulls the plug right out:
Plug extracted:
Hole being tapped for pipe plug:
New threads cuts:
"AN" aluminum pipe plug coated with industrial marine-grade epoxy ready for installation:
Plug installed:
Plug then covered with the industrial grade epoxy to "disguise" the plug. The epoxy is not sealing the leak: The pipe plug is sealing the leak. The epoxy is only a thread sealant and a filler to make the repair less obvious:
Completed repair. This inlet plug will never leak again:
Contact me if you need assistance for the repair.
Lars
Plug extracted:
New threads cuts:
Plug installed:
Lars
Saw a sign in a jewelry store.
Watch Repair $25.00 / Hr
If you watch $35.00 / Hr
If you tell me how to fix it $50.00 / Hr
if you tried to fix it yourself $100.00 / Hr
Just me but watches, carbs, differentials, transmissions and trailing arms are something for professionals.
You might be fully capable and if so just have a laugh.
Lars
