Burned Resistance Wire on 1972 C3 - Converting from External Regulator to 10SI In
Old May 19, 2026 | 05:38 AM
MidnightC3Driver's Avatar
MidnightC3Driver
Cruising
Default Burned Resistance Wire on 1972 C3 - Converting from External Regulator to 10SI In
Hi everyone,
I recently discovered that the brown/white resistance wire from the ignition switch got burned/melted on my 1972 Corvette C3 small block. Because of this, I suspect that either the original externally regulated alternator or the external voltage regulator may have failed.
I have therefore decided to convert upgrade the car to a Delco 10SI internally regulated alternator (63 amp) and completely remove the external regulator.
My current plan is:
  • Install a Delco 10SI 63A alternator
  • Remove/bypass the external voltage regulator
  • Replace all old charging system connections and damaged wiring
  • Upgrade the main charging wire to 6 AWG
  • Install an 80A fuse on the main alternator output wire
  • Replace the burned brown/white resistance wire completely
  • Run a short jumper from terminal 2 (sense) to the B+ output stud on the alternator
  • Connect terminal 1 (exciter wire) to ignition-switched 12V using a 10 ohm / 10 watt resistor in series
  • Add new engine/frame ground cables as well
I do NOT want to use the old resistance wire anymore because it was already damaged.
From what I understand, the resistor should prevent engine run-on/backfeeding when the ignition is switched off.
Does this setup sound correct and reliable for a street-driven C3 Corvette?
Am I missing anything important before I start wiring everything?
Thanks a lot for your help.
Old May 19, 2026 | 09:17 AM
pspicci's Avatar
pspicci
Pretty sure a 72 should have come with a internally regulated alternator. I have a 71 and it is internally regulated.
Pat
Old May 19, 2026 | 09:20 AM
pltmgr's Avatar
pltmgr
Im confused, once again. I thought 72's had internal alternator regulators.
Old May 19, 2026 | 09:56 AM
Alan 71's Avatar
Alan 71
Hello,
I too thought 72 engines had an internal regulator. ??
Regards.....
71 SB,
What part does the resister wire play in the ignition system?
I don't think I ever hear it mentioned?
Is this what MC3D asks about?
Old May 19, 2026 | 10:36 AM
MelWff's Avatar
MelWff
Starting in 1969 all Corvettes had internally regulated 10SI alternators.
In addition they had fusible links on the main output wire.
Do you have the factory wiring diagram for the charging system?
Can you post a picture of the " external" regulator?
Old May 19, 2026 | 12:06 PM
MidnightC3Driver
Cruising
Please excuse my misunderstanding - it’s of course an internal regulated alternator..
Attached is the diagram an I’ve marked the brown-white cable which was attached to the ignition switch.
What I’ve understood is that the cable meltdown could be caused by a broken diode plate in the alternator- that’s why I want to replace the existing one.
Old May 19, 2026 | 01:31 PM
sunflower 1972's Avatar
sunflower 1972
If the diode trio in the alternator is bad, you replace it.
Diode trio 10si alternator
Old May 19, 2026 | 01:35 PM
sunflower 1972
As a matter of fact, all the internals of a GM 10si alternator are replaceable. And that includes the stator and the rotor, which is not shown in the photo.
Old May 19, 2026 | 06:02 PM
MelWff's Avatar
MelWff
Did you check the DC output to see if it's 13.5 to 14.5 volts?
Did you check the AC output which if any would indicate a bad diode?
Did you look at the stamping on the current alternator to see what amperage it is?
Old May 20, 2026 | 11:21 AM
MidnightC3Driver
Cruising
No, unfortunately I didn’t take any measurements. What happened was that I noticed the brown-and-white resistance wire and immediately started disassembling everything. I removed the ignition switch, disconnected the wire from the switch, and also loosened the wiring harness behind the dashboard because it looked like there may have been an electrical short or wiring burn. I wanted to fix the issue as quickly as possible, so I also decided not to start the vehicle again afterward.
Regarding my old alternator, the number stamped on it is 1100921. After doing some quick research, I found that it was probably originally rated at 61 amps, although I’m not completely sure about that.
I have already ordered a new alternator, a 63-amp Delco 10SI. However, I’m still unsure about the best way to wire it, because I do not want to continue using the original wiring setup with the brown-and-white resistance wire.
picture of the old alternator below:
Old May 20, 2026 | 11:34 AM
MelWff's Avatar
MelWff
It's stamped 61 amps.i would expect bulb filaments to burn out if an alternator put out more than 14.5 volts for a prolonged period of time along with battery failure.
Old May 20, 2026 | 12:00 PM
MidnightC3Driver
Cruising
That makes sense and is actually a very good point.
I never experienced obvious overcharging symptoms like constantly blown light bulbs or a boiling battery, so maybe the issue was not simply excessive voltage from the regulator.
Could a failing diode trio or rectifier inside the alternator have caused excessive current/backfeeding through the brown/white resistance wire and eventually melted it?
Or are there any other common causes that could have melted the original resistance wire?
To be on the safe side, I decided to completely eliminate the old resistance wire circuit and replace it with a new exciter wire setup for the 10SI alternator - terminal 1 connected to ignition-switched 12V through a 10 ohm / 10 watt resistor.
Old May 20, 2026 | 12:37 PM
carriljc's Avatar
carriljc
yeah - something isn't adding up.
From my recollection the resistance wire for protecting points had nothing to do with the alternator wiring.
ALSO - if the 72 is anything like my 68 there is NO alternator malfunction lamp.....also, a higher voltage would mean less current through lamp filaments.
I've been running upgraded alternators for a good 20+ years and my voltage is routinely above 14 vdc. Lamp burnout has been a NON-PROBLEM
Originally Posted by Alan 71
Hello,
Regards.....
71 SB,
Old May 20, 2026 | 01:32 PM
MidnightC3Driver
Cruising
I don’t get it.
I am talking about the resistance wire on the ignition switch on the steering column NOT the resistance wire for the ignition coil.
Does somebody know what could be the reason that this wire burnt down?
Attached the pictures again from the cable as well as from the wiring in a 72 C3
Ignition Switch
Ignition Switch
Melted cable
Melted cable
Old May 20, 2026 | 03:50 PM
carriljc's Avatar
carriljc
Perhaps I am misunderstanding something.
The only resistance wiring I see labeled as such in the 1973 diagram is for Ignition and it is EXPLICITLY labeled as such..... see image below circled in RED.
I followed the brown and white back to the ignition switch and it leads to this location indicated in the image (see brown arrow).... nowhere did I noticed anything labeled "resistance wire"?
WHY do you think it is a resistance wire?
Old May 20, 2026 | 04:23 PM
MidnightC3Driver
Cruising
I think the term “resistance wire” may actually be incorrect in my case.
I originally assumed it was a „resistance“ wire because it has only a single wire conducter behind the brown-white insulation.
So to clarify, I am referring to the brown/white wire from the ignition switch that has only one single conductor.
edit: below the wire path:
Old May 20, 2026 | 04:41 PM
carriljc's Avatar
carriljc
ah. ok then.
Just replace it with another wire of the same colors. Somewhere in it's long life it probably just shorted out to ground. If everything else if fine then it's just another wire. You can try looking around the location where it is burned and check to see if you can locate what it may have shorted to.....
To Burned Resistance Wire on 1972 C3 - Converting from External Regulator to 10SI In
Old May 20, 2026 | 05:07 PM
MidnightC3Driver
Cruising
ah. ok then.
Honestly, I’m not sure whether I can reconnect this cable with a new wire, because I also don’t know where I would even get the correct cable from. From what I’ve read, you’re supposed to use the exact same wire gauge (single conducter), and I have no idea where to source that.
On top of that, even if I repair it now, that doesn’t necessarily mean the same issue won’t happen again in the future.
According to the wiring diagram, this cable goes to the alternator and connects to the exciter wire. That’s why I was thinking about replacing the alternator altogether with a 63-amp 10SI alternator and rewiring the exciter wire with a 10W 10-ohm resistor in between, so the engine shuts off properly when I turn off the ignition.
Does that make sense?
Old May 20, 2026 | 06:07 PM
carriljc's Avatar
carriljc
Your comments about exciter wires do not make any sense to me? BUT I don't know what I'm missing or why you're wanted to modify the wiring???
Do you have the AIM for your year?
On my 68 AIM it gives you Wiring Gauge for associated leads.
Note below that the ONLY Brown lead coming from my ignition switch is a 12 Gauge. You can find 12 gauge automotive wire at any car parts store....or online.
Since my original alternator was the same amperage (I'm using a 145 amp alternator now) as your year and it's a 12 VDC system I suspect you'd be just fine installing a 12 gauge lead as a replacement. Take a look at your AIM.
You see the wiring gauge numbers here:
Old May 20, 2026 | 06:11 PM
robertea's Avatar
robertea
Here is a copy of GM's 1972 wiring diagram. It isn't as clear as I would like, but it is usable. I appears that the resistive wire that you referring to is 24 gauge. I don't know what the resistive value should be for that wire, but in the transistor ignition systems they use resistive wire and they are only 0.5 ohms.
