C3 Front Frame Repair 69 Corvette
Old May 25, 2026 | 09:35 AM
74L82AirRoadster's Avatar
74L82AirRoadster
Default C3 Front Frame Repair 69 Corvette
Hi all,
Has anyone replaced the front inner frame horn gussets? Mine are rusted as shown below. Corvette Central offers the part so someone has had to replace them. Any help would be greatly appreciated.
Old May 26, 2026 | 09:38 AM
Alan 71's Avatar
Alan 71
Hello,
In looking at your photo it appears the damage is more likely to have been caused by a 'collision' than 'rust'
If that's the case perhaps the front of the frame rail needs to be checked too.
What does the front bumper brace look like?
Regards......
Old May 29, 2026 | 05:04 PM
ACfarmerNH's Avatar
ACfarmerNH
I replaced the frame on my '72 with one from a '74 and had to change the frame horns. I cut the welds with a cutoff wheel and believe that I used threaded rod and some nuts to help position the new one within the actual frame's openings while welding it in place. In an attempt to protect the frame, cleaned and painted the frame and then ground some of that off for the new welds.
Old Jun 1, 2026 | 10:08 PM
standardbyke22's Avatar
standardbyke22
I had to replace those on my 68, same thing rust hole and metal swelled out, cut welds and line up new one and weld in, easy. also sprayed weld through primer on back sides then internal frame coating after welded.
Old Today | 12:41 AM
leigh1322's Avatar
leigh1322
Old Pro Solo Guy
According to frame guru David Howard (RIP) bolt hole locations in those frame horns varied a couple of times over the years.
Vette Products of Michigan actually makes them.
Make sure you get the correct ones for your year.
To C3 Front Frame Repair 69 Corvette
