Wiper Arm Washer Tubes
Passenger's on left - Driver's on right
The driver's tube is routed so the cupped end of the hold down tab actually holds the tube against the wiper arm.
The passenger's tube is routed so it runs under the hold down tab between the tab's rivet and the cupped end. It does not run thru the "cup." The hold down tab actually appears to be riveted in place upside down from what I'd expect. The AIM doesn't show enough detail for me to see how they should be.
Is this "normal" factory configuration for similar year C3s?
Thanks
Here are a few photos of 71 'tubes'.
Hopefully they'll help you determine just what you have at this point.
Regards.....
The old Paragon catalogues have a nice drawing showing the various clips and just where they snap onto the arms.
Right Side
Right Side
Right Side
Right side
Right Side
Left Side
Left Side
Left Side
Left Side
A couple nylon clips missing.
I don't know why GM would make a piece and then not solder it together, but they have done other things that make me scratch my head.
Now I just need to track down and order the various missing little plastic clips!
I repaired a set of arms and tubes for someone and both showed a solder connection although one side had broken loose.
Regards....
Trying to duplicate the thin black coating on the arms with black oxide.
Have to remove the coating from the tubes and other parts of the arms that weren't black
Regards.....
Paragon was started by Richard Fortier.
A man with unfailingly accurate parts knowledge.
He was able to offer the 69 side exhaust system!
He also offered very accurate exhaust tips for 70-72 cars. (He even controlled the prep and plating so the finished product wasn't too perfect).
The 2 most important sources for parts information were/are Dr.Rebuild and Paragon.
Regards....
These are the result of his efforts.
He even built a thin plywood box to ship them in!!!
Note the 'tab' on the front and the width of the black stripe.
