power steering slave cylinder (ram)
Old May 31, 2026 | 10:09 AM
joec's Avatar
joec
Default power steering slave cylinder (ram)
So... I was at a car show and had my power steering go out as I was trying to back into a space.. looked under the car and saw a leak that I found out started a ways back while to my spot... so I nursed it home and this morning I filled the fluid back up and jacked up the car... what I saw is in the pic.. Now this part is only like 2 months old... soooo, my question is do I rebuild it or just get another one?? also after taking it out and replacing it do I have to go through the whole process of balancing it with the control valve or just slap it in and make sure I have no air in the system... Thoughts appreciated...
Old May 31, 2026 | 10:36 AM
MelWff's Avatar
MelWff
If the surface of the rod is worn or damaged rebuilding will not work. Consider a new one from Lonestar
Old May 31, 2026 | 10:39 AM
joec's Avatar
joec
thanks mel... ya like i said it's only 2 months old and mechanic said he got it from lone star but I have no receipts that it did...
Old May 31, 2026 | 10:42 AM
Rebelyell's Avatar
Rebelyell
either convert to manual vette box (no ram)
OR
Convert to a Borgeson PS box (which also has no ram)
FWIW
FOMOCO briefly did use a ram-type hydraulic cylinder too.
Old May 31, 2026 | 10:44 AM
MelWff's Avatar
MelWff
Would expect it to have a warranty for the part, check with the mechanic
Old May 31, 2026 | 11:05 AM
barkingrats's Avatar
barkingrats
1967 Pedal Car Champion
New ones are more than likely made by Lares - even the Lone Star choice. You can get the same part from Summit ($185), Rock Auto ($175), Zip ($225), etc. Lares also sells reman cylinders. I have a Lares power steering pump in my '72 and have had no problems at all.
Old May 31, 2026 | 11:08 AM
joec's Avatar
joec
normally I would but we had a falling out after he couldn't fix my rms leak twice... I'll just have to eat this one...
Old May 31, 2026 | 11:09 AM
joec's Avatar
joec
I was thinking summit and rock auto also... just wondering if I have to balance the system again...
Old May 31, 2026 | 11:16 AM
MelWff's Avatar
MelWff
No, the valve pressure is balanced, ram can be changed without touching valve
Old May 31, 2026 | 11:52 AM
joec's Avatar
joec
Originally Posted by MelWff
No, the valve pressure is balanced, ram can be charged without touching valve
thank you...
Old Jun 3, 2026 | 04:47 PM
joec's Avatar
joec
Default quick uodate
so I got the new slave cylinder in and all back together.. however the bottom hose was a real PIA to get in... after doing some more research to me it looks like the mechanic who previously put this in has reversed lines???? while they go correctly to the right spots I think the hoses should be swapped??? thoughts???
Old Jun 3, 2026 | 06:09 PM
MelWff's Avatar
MelWff
Top line on valve goes to bottom of cylinder, bottom line on valve goes to top of cylinder and loops over lower hose at the pipes.
Does it steer correctly?
Did you look at online diagrams?
Old Jun 3, 2026 | 07:01 PM
joec's Avatar
joec
Ya steers fine but I think the hose lengths look off to me and think they should be reversed... I'll look for some diagrams tho..
Old Yesterday | 05:34 AM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
If you reverse the lines it will push when you need it to pull. And pull when you need it to push. The car will be undriveable.
Old Yesterday | 06:13 AM
jthornton's Avatar
jthornton
I assume you're saying swap hoses and I'll check mine in a bit and get you a photo. Mine were clearly marked where they go and one hose has a large radius and one a smaller radius on the valve end.
JT
Old Yesterday | 06:31 AM
jthornton's Avatar
jthornton
Here's my 82 control valve and cylinder hoses.
So your hoses are installed correctly but the one hose is too long as you can see mine are made in USA so they fit perfect.
JT
Old Yesterday | 07:15 AM
joec's Avatar
joec
thank you!!
ya, yours look much better then mine... where did you get them???
thanks...
To power steering slave cylinder (ram)
Old Yesterday | 07:20 AM
Bikespace's Avatar
Bikespace
OR
FWIW
You beat me to it!
These are the best solutions (though a third could be a rack and pinion swap).
Old Yesterday | 08:05 AM
jthornton's Avatar
jthornton
thank you!!
thanks...
Mid America Motorworks
602-476 1963-1982 Corvette Power Steering Low Pressure Return Hose
602-474 1963-1982 Corvette C2-C3 Power Steering Small Loop Extension Hose
602-472 1963-1982 Corvette C2-C3 Power Steering Big Loop Retract Hose
602-468 1980-1982 Corvette Power Steering Small Block High Pressure Hose
JT
Old Yesterday | 09:34 AM
MelWff's Avatar
MelWff
thank you!!
thanks...
You cannot compare the two pictures unless the ram on both pictures is extended the same amount. The hoses flex as the ram moves.
