Throttle lag
Old Yesterday | 06:12 PM
PRL1941's Avatar
PRL1941
Default Throttle lag
I have a stock 2015 C7Z06 M7. what is the best way to lessen that new throttle body or controller?
Old Yesterday | 07:43 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
You are not giving us a lot of information so I have no idea of what you're asking !!..."lessen that new throttle body" ??...below is part of a TSB...some types of lag are NORMAL !!
Some customers may comment on a sag or hesitation when accelerating under the following conditions:
  • When coasting at low speeds of less than 24 km/h (15 mph) with a closed throttle and then aggressively applying the throttle.
  • Examples of this maneuver include a rolling stop or a lane change maneuver. In this type of maneuver, even though the accelerator is applied aggressively, the throttle blade is opened slowly for up to 0.7 seconds to help minimize driveline lash and clunking.
  • Also, in a vehicle equipped with an automatic transmission when making a hard, complete stop with a closed throttle, immediately followed by an aggressive throttle opening, the transmission downshifts may not be completed by the time the throttle is opened.
  • As a result, approximately 0.5 seconds of ″zero″ torque may be commanded to allow the shift to first gear to occur.
Customers may also comment on a sag or hesitation while cruising at highway speeds and then aggressively increasing the throttle, forcing a down-shift.
    • This type of driving maneuver may result in approximately 0.5 seconds of ″zero″ torque being commanded to allow the downshift to complete.
Old Yesterday | 08:03 PM
kodpkd's Avatar
kodpkd
Soler Throttle controller. Easy to install, works good.
Old Yesterday | 08:22 PM
Blackcherry20's Avatar
Blackcherry20
I Love My C7
^^^ This. Doesn’t have to be Soler btw.
Old Yesterday | 09:13 PM
PRL1941's Avatar
PRL1941
What mm would you recommend 87,91 or 93? Have you done that before and did it eliminate it or just lessen?
Old Yesterday | 09:14 PM
PRL1941's Avatar
PRL1941
If not Soler what and what size mm?
Old Yesterday | 09:22 PM
Blackcherry20
I Love My C7
@smitty2919 can recommend w detail.
To Throttle lag
