69 Leaf Spring Bolts at Diff
Old Yesterday | 02:25 PM
mtcarl's Avatar
mtcarl
Default 69 Leaf Spring Bolts at Diff
Just had the original diff rebuilt and have it all mounted except for the leaf springs. I decided to order replacement bolts for mounting to the diff. Ordered the 3.5" bolts for this 9 leaf spring from a major supplier. The original bolts measure 3.5" from the tip of the threads to the top of the head. As you can see from the attached photos that the new bolts are about .25" longer than the originals. Leaf spring, bolts, mounting bracket and diff are all original. I read about the critical nature of the bolt lengths to avoid damaging the diff case. Will the new bolts be too long?
Thanks
Mike
Old Yesterday | 04:45 PM
69L88's Avatar
69L88
Why not just put the originals back in?
Old Yesterday | 05:07 PM
mtcarl's Avatar
mtcarl
I've had one bolt break at the half-shaft yoke cap and one at the end of the rear stabilizer to the bracket on the trailing arm. Took a lot of work to get the broken stub out of the (brand new) yoke. Both were original bolts and before reaching torque.value. You might say I'm a little gun shy. Maybe I'll try to rig up a bench test to see if the original bolts can make it to 60 ft lbs. Another option might be to cut off the new bolts to match the originals. Return postage for the new bolts probably won't leave much credit.
Old Yesterday | 06:25 PM
Alan 71's Avatar
Alan 71
Hello mtc,
Having a bolt damage the rear differential case would likely spoil your whole day.
So.....
Regards....
I believe the 2 front bolts holes are 'blind', while the rear 2 holes are open.
Note the heavy lock washer.
Old Yesterday | 07:59 PM
Rowdy Rat's Avatar
Rowdy Rat
Veteran: Marine Corps
The original bolt for all 1968 to 1974 Corvettes (as well as all 1963 to 1967 Corvettes) was 3833486 which had a length of 3 7/32”.
Your original bolt appears to be roughly 3 1/4” long which is just about right on spec.
Your replacement bolts are too long… I wouldn’t attempt to use them.
Regards,
Stan Falenski
Old Yesterday | 08:12 PM
GTR1999's Avatar
GTR1999
Inside a rear cover that had the wrong bolts installed. Cracked the boss, oil leaked out, cover was wrecked.
Check hole depth, spring thickness, thread length to figure if it will work.
Old Yesterday | 09:26 PM
lars's Avatar
lars
Thanks
Mike
Why don't you just shorten the new bolts to the correct length? It would take about 5 minutes, which is less time than you've spent discussing the matter on this thread...
Old Yesterday | 09:49 PM
69L88's Avatar
69L88
Your original bolts were fabricated in the USA by a company based in the USA to SAE J429/ASTM 354 standards. In today’s world, I doubt most suppliers are willing (or able) to identify the source of what is sold, let alone the specifications to what material they are fabricated from and the manufacturing standards.
From your pictures, I would not hesitate a New York minute to reinstall them.
Old Today | 04:10 PM
mtcarl's Avatar
mtcarl
OK, I've decided to reuse the original bolts. Thanks for all the tips and opinions.
To 69 Leaf Spring Bolts at Diff
