passenger side ac question
Old Jun 11, 2026 | 02:01 PM
Stop Flop's Avatar
Stop Flop
Supporting Vendor
Default passenger side ac question
I live in south flordia and very hot. My drivers side ac is cool but the passenger side seems not a cool. Is this normal
dave
Old Jun 11, 2026 | 02:13 PM
RonC7's Avatar
RonC7
Not normal. Air temp out of all vents should be about the same assuming driver and passenger set temperature is the same. If you press SYNC you can just adjust the driver temp and passenger will match.
1) verify passenger side set temp matches driver side
2) had this issue on DD and car was low on refrigerant
3) least likely pass temp actuator could have failed
Ron
Old Jun 11, 2026 | 02:44 PM
Stop Flop's Avatar
Stop Flop
Supporting Vendor
thank you!
Old Jun 11, 2026 | 11:06 PM
RonC7's Avatar
RonC7
Let us know what repairs are needed. That's how we all learn.
Ron
Old Yesterday | 09:56 AM
Stop Flop's Avatar
Stop Flop
Supporting Vendor
I will
dave
Old Yesterday | 10:05 AM
SEVNT6's Avatar
SEVNT6
Me too on my wife's car...
Old Yesterday | 10:11 AM
Let It Ride's Avatar
Let It Ride
Like Ron said classic case of low freon. I've seen it a million times. 99% sure that is your case.
Old Yesterday | 10:15 AM
Stop Flop's Avatar
Stop Flop
Supporting Vendor
Thanks!
Dave
Old Yesterday | 05:41 PM
jdaniels138's Avatar
jdaniels138
Veteran: Marine Corps
I had this done a couple months ago at the dealership. Cost was about $3,500.
See the posts here:
Hvac issue
/JD
Old Yesterday | 05:46 PM
RonC7's Avatar
RonC7
Most any competent shop can check A/C and recharge for a couple hundred dollars.
Don't need a dealer.
Ron
Old Yesterday | 06:10 PM
ZO6LIFE's Avatar
ZO6LIFE
Classic GM low on freon case. My estimate is 1.4 pounds low
Old Yesterday | 06:11 PM
jdaniels138
These cars have known issues with the actuator doors malfunctioning, which causes the symptoms you mentioned. Hopefully, this isn't the case for you. However, a shop can easily scan for OBD-II trouble codes to confirm the issue. If you have a code reader, you can also check this yourself. Just note that replacing the actuators usually requires disassembling the dash. Your situation sounds exactly like the problem I and many others have faced.
See the thread I noted above in my post, #9
/JD
Old Yesterday | 07:24 PM
kodpkd's Avatar
kodpkd
If your passenger side is set to 75* ish and the drivers side isn't in sync that is very normal.
Old Yesterday | 07:37 PM
peterepetepete0@gmai's Avatar
maybe be the ac mode actuator behind the dash cant you sync them to same temp??? then you should feel the differnce if there is any
To passenger side ac question
