Starter Wire Bundle Sleeving
Old Jun 15, 2026 | 10:10 PM
pl2000n's Avatar
pl2000n
Default Starter Wire Bundle Sleeving
Hello Everyone, so, after a bit of time with headers on my 427, the starter wire bundle has had quality time resting on the headers (unplanned). The high-temp sleeving has melted (and wires, blew the main buss fues), and I'm dang lucky an electrical fire didn't result. I would appreciate a good high-temp sleeve replacement source for this bundle. I found one, but it's from China and will take 2 weeks to get here. I don't trust it. Thank you very much.
Old Jun 16, 2026 | 08:45 AM
Alan 71's Avatar
Alan 71
Hello pin
Have you tried lectric limited?
I see they offer the alternator wire sheath and may be able to help you with your starter bundle.
Regards....
Old Jun 16, 2026 | 08:52 AM
Corvettedave02's Avatar
Corvettedave02
C3. 427, 4-link, c7 z06
I mounted a power bar to the frame close to the starter and then ran only TWO wires to the starter lug. I also put heat wrap around the main power cable going to the starter lug. I also put a 175 -20@ amp marine fuse on the main power cable at the battery at the suggestion of Richard. I’ll try to find some pics.
Old Jun 16, 2026 | 09:09 AM
barkingrats's Avatar
barkingrats
1967 Pedal Car Champion
You mentioned the hi-temp sleeving you had on there melted - what material was that?
I'd think spark plug boot sleeve made of fiberglass may work or high-temp tape (1100°F).
GM made a starter solenoid heat shield that will fit your 427. I have one on both of my cars just because the manifolds are only a couple inches from the solenoid and wires. GM also had a wire clip that mounted to the solenoid to keep the wires up and back from the exhaust.
Old Jun 16, 2026 | 12:35 PM
pl2000n's Avatar
pl2000n
Originally Posted by Alan 71
Hello pin
Regards....
Thank you Alan 71, I will reach out to them. I've repaired the actual wires myself with quaility wire and heat shrink, so I just need the high temp sleeve. I appreciate your note.
Old Jun 16, 2026 | 12:43 PM
pl2000n's Avatar
pl2000n
Nice work! I'll take some tips here. What was your source of the the heat wrap on the starter itself?
Old Jun 16, 2026 | 12:47 PM
pl2000n's Avatar
pl2000n
Thanks barkingrats, I'm not exactly sure what the material was but it looks OEM. Do you have a source for the shield in your photo?
Old Jun 16, 2026 | 01:14 PM
barkingrats
Reproductions of both the shield and wire clip are readily available at most of the regular vendors. The shield attaches to the block using the front starter support bracket and the rear uses the outer screw/nut of the solenoid cover.
Old Jun 16, 2026 | 04:20 PM
71 Vert LS1's Avatar
71 Vert LS1
I've used DEI wire/cable insulation on my hot rod projects. Looks like the silver wrapped cable shown above.
Old Today | 10:34 AM
pl2000n's Avatar
pl2000n
Thanks everyone for you suggestions and help. My chinese high-temp sleeve finally arrived. Here's a link for those who may be looking such an item:
https://www.harfington.com/products/...hoCE68QAvD_BwE
To Starter Wire Bundle Sleeving
