Speedometer off
Old Yesterday | 11:08 PM
Bfemrite01's Avatar
Bfemrite01
3rd Gear
Default Speedometer off
I have a 75' 4 speed and the speedometer shows a good 10 MPH faster than what It is actually going, thus causing the odometer to also add miles too fast. I am not sure what to check first, thinking it is part of the nylon gear being stripped or a broken clip. Is this the first thing I should be checking or has anyone seen this problem before?
Old Today | 02:13 AM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
If it's stripped it would read slower. That's not it.
What size tires are you running?
Possible incorrect gear in transmission. What color gear do you have? What rear gear are you running?
