DRM brake bias spring install?
Old Jun 1, 2003 | 07:12 PM
myscx's Avatar
myscx
Default DRM brake bias spring install?
How hard is this to install?
Old Jun 1, 2003 | 07:45 PM
Slalom4me's Avatar
Slalom4me
Default Re: DRM brake bias spring install? (myscx)
Not very..
Try a search using 'bias' and archived topics
There were lots of posts when I just did this and
here is one of the first threads that came up - seems
to be tailor made for your question:
http://forums.corvetteforum.com/zerothread?id=531144
Old Jun 1, 2003 | 07:46 PM
Bluevette85's Avatar
Bluevette85
The tough part is figuring out a way to compress the bias spring to get the c-clip into place. You'll need a vise or a adjustable clamp.
jackdaroofer's Avatar
jackdaroofer
From: Almost all Skyline Cruises Vettes at Waterside 1-5
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
:cheers: Harder than they make it sound :smash:
You don't have to remove the MC, just the large nut on front of MC
The valve assembly comes out in one piece...have a helper step slowly on the brake pedal, this will help to free it. I used a file with a sharp pointe end, bent the end into a hook and grabbed it by the "slot" you will see
That was the easy part!
The "C" ring is on the backside and "C" ring pliers are required
Getting the old spring out is fairly straight forward once you remove the "C" ring
Getting it back in and securing the "C" ring is another story. I made a fixture that would allow me to compress the spring, with the "C" ring attached to the fixture so that as I put pressure on it with a C clamp, the spring and the "C" ring were compressed into the cylinder simultaneously. The when the "C" ring was at the end od the cylinder, I used the "pliers to pull it together while I continued to turn the C Clamp until everything moved into the cylinder and I could release the "pliers"
Now that I have done it, it is a piece of cake :D Sort of like changing the third brake light bulbs in a vert :D
If I can me of further asistance, let me know
:seeya
:steering:
Old Jun 2, 2003 | 12:44 AM
93Quasar's Avatar
93Quasar
I guess a more general question: What does the spring do for you?
I am going to upgrade my 93 front brakes to GS J55. Will I need to install this spring?
Old Jun 2, 2003 | 06:25 AM
bill mcdonald's Avatar
bill mcdonald
Default Re: DRM brake bias spring install? (Jeff Hickman)
It adds a little more bias towards the rear brakes.
Old Jun 2, 2003 | 11:03 AM
ShawnZR-1's Avatar
ShawnZR-1
St. Jude Donor '03-'05-'06-'10-'11-'12
I just did this install this weekend! It took me and a friend to get the spring into the piston!!! That was a royal PITA! Unfortunately, I haven't had a chance to drive it yet (way too busy over the weekend).
I used a clamp, a 7 or 8 mm (1/4 inch drive) socket (to compress the spring) and 4 hands! Oh, get a good snap ring plier, it makes the job possible! :yesnod:
Old Jun 2, 2003 | 01:07 PM
93Quasar's Avatar
93Quasar
Default Re: DRM brake bias spring install? (ShawnZR-1)
Let me know what you think of it. I guess what I should have asked is what are the consequences of going to J55 or C5 brakes and not doing this change?
Old Jun 2, 2003 | 03:31 PM
bill mcdonald
I dont think it is much of a big deal. I had the 12" rotors and calipers on my car, I put the 13" rotors and GS calipers with race/street pads on it. stops good now.
I want to install my spring as well, but I hear it is a PITA, and I think I just want to drive it for now
Old Jun 2, 2003 | 03:40 PM
ShawnZR-1's Avatar
ShawnZR-1
I'll let you know, but I also replaced the brake lines with stainless steel braided at the same time. I won't be able to provide a completely objective synopsis of the results. I'm expecting some shorter stopping distances and using the rears a bit more (20% more?), I should accomplish that! :cheers:
Old Jun 2, 2003 | 05:11 PM
TheCorvetteKid's Avatar
TheCorvetteKid
I actually bought one of these brake bias springs about 2 years ago, but never installed it. And now that I'm hearing the kind of difficulty some of you have experienced, I may not.
But did you all have to bleed your brakes after you installed this spring? I'd probably reconsider going through the agony of trying to install it knowing that at least I don't have to bleed my brakes after I'm done.
Thanks.
Old Jun 2, 2003 | 05:13 PM
ShawnZR-1's Avatar
ShawnZR-1
Default Re: DRM brake bias spring install? (TheCorvetteKid)
Oh, you definately have to bleed the system when you are done! :yesnod: I won't lie to you there! :crazy:
Old Jun 2, 2003 | 08:44 PM
jackdaroofer
Cruise-In I Veteran
Cruise-In V Veteran
:cheers: Installing the spring is definitely worth the effort...IMHO
It does work! Brings the rear brakes into play, shortens stoping distance.
If you live near me, or you want to send me the valve assy and the spring, I will install it for you for the cost of shipping only. Like I said, I fabricated a 'fixture" that makes it fairly easy to compress the spring and install the C ring
Happy to do it
e mail me
Jack
PS You will need to bleed the MC and maybe the brakes too
:seeya
Old Jun 2, 2003 | 08:49 PM
jackdaroofer
Cruise-In I Veteran
Cruise-In V Veteran
Thanks.
Bleeding the brakes isn't all that difficult, you can do it by yourself and without speed bleeders. Gravity bleeding works great, just takes a little longer.
You really should change the brake fluid every two to three years, more often if brakes get hard use
:seeya
:steering:
Old Jun 2, 2003 | 09:20 PM
NHVett's Avatar
NHVett
Cruise-In I Veteran
msscx Hey, could you email me, I grew up in Five Islands and drive my red 85 down there several times a year.
Old Jun 2, 2003 | 09:34 PM
jackdaroofer
Cruise-In I Veteran
Cruise-In V Veteran
Default Re: DRM brake bias spring install? (NHVett)
:cheers:
When are we gonna meet up again?
I'll be in ogganaguit (spelling) Maine in late July
Jack
Old Jun 2, 2003 | 09:36 PM
Zora's Avatar
Zora
Cruise-In I Veteran
Default Re: DRM brake bias spring install? (jackdaroofer)
:seeya
:steering:
:iagree:
To DRM brake bias spring install?
Old Jun 2, 2003 | 10:03 PM
black bart's Avatar
black bart
This is a bargin mod how many things can you do to your car that will improve the performance for less than $ 15.00 I installed mine with a pair of snap ring pliers and a small screwdriver and yes it is kinda hard to get it in but not impossible.
Old Jun 3, 2003 | 12:36 AM
87SAM's Avatar
87SAM
Default Re: DRM brake bias spring install? (black bart)
My memory isn’t serving me very well right now. What brand/manufacture of spring did you use? It seems one particular brand had a very good endorsement here on the forum…
Duh!!! Maybe DRM would be a clue :crazy: :crazy: :crazy:
[Modified by 87SAM, 10:38 PM 6/2/2003]
Old Jun 5, 2003 | 01:17 PM
ShawnZR-1's Avatar
ShawnZR-1
Default Re: DRM brake bias spring install? (87SAM)
Well, after driving the beast for a couple of days, I can give some feedback on the upgrade:
DO IT! There's no doubt it shortens the stopping distance dramatically! Hell, for the first time ever, I have dust on the rear wheels (now, is that really a good thing?) :lol: It proves the rear brakes are coming into play now!
Modulation is much better. I can threshold brake right up until ABS kicks in much better now. It used to come on suddenly when one of the front wheels locked up quick, now it brakes harder longer without ABS. Does this make sense? It's kinda hard to describe. Even when ABS kicks in, it's a quick stop.
