Southern California Southern California
Starter
Old Mar 20, 2011 | 06:35 PM
VETTEZILLO's Avatar
VETTEZILLO
Default Starter
I need some information. My C5 wouldn't start. It just made a clicking noise but wouldn't start. The battery has been checked and is good. The cables were on tight making a good connection. The alternator also checked out and is good. The next thing I was going to check is the starter. However I went under the car to check it out but the headers are in the way. Before I go that direction is there anything else that might be the problem? If it is the starter, do I really have to drop the headers to get to it? Any help would be appreciated.
Old Mar 20, 2011 | 08:33 PM
frank dupuy's Avatar
frank dupuy
The symptoms are indicating a low charge in the battery. Are you sure the battery is fully charged. This needs to be checked first before anything else.
Old Mar 20, 2011 | 09:04 PM
quickc6's Avatar
quickc6
I agree with Frank . You all so need to check the connection at
the starter and grounds.
Good luck Tris
Old Mar 21, 2011 | 02:29 PM
Dennis Wilson's Avatar
Dennis Wilson
Rocky, I have a charger with a quick start feature . If that works & it starts, you could rule out the starter. Most of the time the probs. are the Batt. or a ground prob. Let me know if you want to try it. Dennis.
Old Mar 21, 2011 | 03:10 PM
bearphoto's Avatar
bearphoto
SoCal Events Coordinator
St. Jude Donor '12
I agree with dennis and the others, try jumping or putting the quick start charger on it, if it starts you have yourself a battery issue, if it does not start and the battery cables are all tight with no corrosion then look to the starter or connections down there.
Old Mar 21, 2011 | 04:46 PM
NORTY's Avatar
NORTY
Your battery needs to be "load tested." That's the only way to test. Otherwise, it's a connection somewhere.
Old Mar 21, 2011 | 08:41 PM
VETTEZILLO's Avatar
VETTEZILLO
Thanks for all the good advice. After rechecking everything I found the that the battery bolt extender was bad on the positive post. I replaced it and all is fine. Yahoo!! I'm up and running again!!!!!!!
Old Mar 21, 2011 | 08:50 PM
Dennis Wilson
Old Mar 21, 2011 | 09:51 PM
Wildmanht's Avatar
Wildmanht
Corvette Forums to the rescue!! Got to love the help here... Congrats that it wasn't your starter.
To Starter
