ie7 test
Jun 22, 2008 | 09:27 PM
Testing After Changing Editing Options In The User Control Panel ... This Sentance Was Typed With All Caps.
Jun 22, 2008 | 09:32 PM
Another Test After Playing With User Cp Settings ... This Sentance Was Typed In All Caps.
Jun 22, 2008 | 09:38 PM
Test With Mozilla 2.0 ... This Sentence Was Typed In All Caps.
Jun 22, 2008 | 09:41 PM
Per post #23 it does not care if I use Mozilla, IE6 or IE7 ... it still automatically changes the sentence if it's typed in all caps.
It has to be a feature of the site. Admin/Mods ... can you add any info?
Jun 22, 2008 | 11:00 PM
TEST USING ALL CAPS, BUT USING A SMILIE THAT IS CODED WITH SMALL LETTERS ....
Jun 22, 2008 | 11:01 PM
Doing The Same With All Caps As The Post Above, But Using The Smilie With The Cap Letter Coding ... :d
Jun 22, 2008 | 11:42 PM
CI 3-4, 8-9-10 Veteran
St. Jude Donor '06-'08-'10
All Caps On Firefox. I Believe The Forum Has A Software Add On That When A Post Is Done In All Caps It Modifies It To One Upper Case Then Lower Case.
It's Done Because A Post Done In All Caps Is Tough To Read And In The Internet World Considered As Yelling.
Jun 22, 2008 | 11:43 PM
Quote:
Originally Posted by
Blue 92
All Caps On Firefox. I Believe The Forum Has A Software Add On That When A Post Is Done It All Caps It Modifies It To One Upper Case Then Lower Case.
Adding a smiley or other lower case probably bypasses the upper case conversion routine.
Jun 22, 2008 | 11:52 PM
Blue 92
Yes is does, depending on exactly what smilie is used ... it has to be coded in small letters. Next post will be an example of getting past the non all caps post.
EXAMPLE OF A POST IN ALL CAPS IN SUCH A WAY AS TO BY-PASS THE SITE'S AUTO REFORMATTING TO NOT ALLOW A POST IN ALL CAPS ...
