Wheels & Tires Corvette Wheel & Tire Sizing Info, Staggered Fitment, Tread Compound, Tire Pressure, size option
ET Street & Wheel Compatiblity
Old 10-18-2005, 08:59 PM
YLWFVR75
YLWFVR75's Avatar
SE Michigan Coordinator
CI 3, 4, 5, 6, 10 Veteran
St. Jude Donor '09-'11,-'13-'14-'15
Default ET Street & Wheel Compatiblity
Next spring, i'm upgrading my coupe's 4 corners with new wheels and tires. In the back were going to a 19 x 10 rim, mounted with a 295/35/19 tire.
I want to use my stock front 17" wheels, to mount some ET Streets for the track. My concern is how the tire diameter will affect my shiftpoints. Based on Michelin's site, the tire diameter for a 295/35/19 tire, is 27.1
Any recommendations on ET Streets that would fit the 17" wheel, and avoid any conflict with the shiftpoints?
Old 10-19-2005, 10:18 AM
Allthrottleandsomebottle
Support Corvetteforum!
Allthrottleandsomebottle's Avatar
Virginia Events Coordinator
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
NCM Ambassador
going to a 19 x 10 rim, mounted with a 295/35/18 tire.
18" or 19"?
If you are going to a 19"..........
Our 00' vert on the street run's 295/35/19. On the strip a 275/35/18 dr.
The key is to have the car tuned for the smaller tire diameter.
Ours works fine that way
Old 10-19-2005, 02:17 PM
YLWFVR75
YLWFVR75's Avatar
ooops, mistake.. .19" on the back...
To ET Street & Wheel Compatiblity
Quick Reply: ET Street & Wheel Compatiblity
