I would suggest calling Luke, he will be able to help you out and get you the right wheels with the right tires.
Those wheels look really good on your ride!
Unfortunately, neither Luke nor the Michelin Tech Line recommend the 245/45 on a 9.5" rim. As I said before, I just don't understand, as the tire has a 9.6" section width, which IMHO should be wide enough for that rim.......
