Wheels & Tires Corvette Wheel & Tire Sizing Info, Staggered Fitment, Tread Compound, Tire Pressure, size option
tpms delete kit
Old Jul 25, 2012 | 04:03 PM
FordDefector's Avatar
FordDefector
So if I have an '01 C5, can I just buy the Z06 receiver to get rid of the TPMS and reprogram my original key fobs? Would I have to get TPMS disabled in the tune so it doesn't give me the warning message on the DIC, defeating the purpose of changing the receiver, or will it just have the code present but not bother me through the DIC?
Old Oct 18, 2012 | 04:40 AM
FordDefector
Nobody knows the answer to this?
Old Oct 18, 2012 | 10:27 AM
DTPDave's Avatar
DTPDave
you dont need to buy anything. Any 01-04 can have the monitors turned off with a Tech2
Old Oct 20, 2012 | 07:20 PM
Dragracer_Art's Avatar
Dragracer_Art
How about an '05 ???
Old Oct 21, 2012 | 04:53 AM
FordDefector
Seems like a Tech2 is prohibitively expensive given what I want it for. I'm guessing a dealership would have a Tech2 but would probably refuse to turn off TPMS for liability reasons.
Is this something that a shop could turn off for me in the tune? I know mine was tuned used HPTuners when the motor was built. It was my understanding that the TPMS is part of the BCM and HPTuners only communicates with the PCM. Is this true?
Old Oct 21, 2012 | 11:41 AM
BEZ06's Avatar
BEZ06
Can't disable the TPMS in a C6!!!
100% of all vehicles (cars/vans/light trucks less than 10,000 lbs) manufactured after Sept 2007 (start of the 2008 model year) must have tire pressure sensors and a TPMS.
For the several years prior to that there was a phase-in requirement where increasing percentages of a manufacturer's vehicles needed to be built with the system until the 100% date was reached.
The C6 came out when this regulation was just starting, and it was built to comply with the requirement.
Like Luke said in a post above, you cant disable the TPMS, at least on a street driven car - if your car is track only, you can do whatever you want and will comply with class rules and your organization's tech requirements.
Here's an except from the NHTSA ruling that says TPMS may not be disabled:
Under 49 U.S.C. 30122(b), "A manufacturer, distributor, dealer, or motor vehicle repair business may not knowingly make inoperative any part of a device or element of design installed on or in a motor vehicle or motor vehicle equipment in compliance with an applicable motor vehicle safety standard prescribed under this chapter...
So, disabling your TPMS would essentially be the same as disabling your airbags or taking the seat belts out of your car.
Any C5 or earlier Vette was built before that regulation, so doesn't need to comply.
However, if you read the fine print on the sidewall of every runflat tire it says that tire pressure sensors must be run in the tires. A zealous insurance agent could probably deny coverage if they found that you didn't have sensors in your runflats when your car ended up in a guard rail on the off ramp because you didn't know you lost pressure while driving down the highway and took the off ramp in your normal spirited manner and lost control due to a flat tire.
Just MHO, YMMV!!
Bob
Old May 15, 2016 | 12:47 PM
David Shiel's Avatar
David Shiel
Default An old post, but
Originally Posted by Luke@tirerack
as federal law states "it is unlawful to eliminate and/or disable the tire pressure monitoring system in any passenger vehicle that is 2008 or newer"
who gives a crap what the Nanny Fed Gov says !! We are lucky that the Feds haven't completely crashed the entire country F'em.
Old May 15, 2016 | 12:52 PM
David Shiel
Default I do't see anything about what an owner can do and,
The C6 came out when this regulation was just starting, and it wasmany have scrapped the runflats built to comply with the requirement.
Just MHO, YMMV!!
Bob
many are not using runflats. And, screw the FEDs as elsewhere.
Old Nov 3, 2016 | 03:07 AM
ericwilloughby's Avatar
ericwilloughby
4th Gear
The business that sold you delete parts can be sued. Thats who cares
Old Nov 3, 2016 | 09:55 AM
David Shiel
Default And, so
[QUOTE=ericwilloughby;1593386999]The business that sold you delete parts can be sued. Thats who cares[/
Wrong, they don't give a fat rat's patoot about these onerous unwanted Federal intrusions either. There are documented cases of run flat catastrophic failures resulting in serious accidents.
Old Nov 3, 2016 | 02:24 PM
ericwilloughby
4th Gear
[QUOTE=David Shiel;1593388047]
Really. U think so. So why is there not a single option to delete the tpms? Name one
