Can the BF Goodrich Comp T/A ZR run flats be used on the 18 x 9.5 and 18 x 11 wheels?
Tire Rack carries 235/40ZR-18, 295/35ZR-18, and 295/45ZR-18. Which of these would you recommend for the front and rear? If it is possible to use these run flats, will I need to lower the car or will the car still appear stock from a distance. I like the stock look; want to avoid the 4X4 look if I get new wheels/tires. I appreciate your feedback.
