Valve spring replacement.
I am not sure what engine you were working on, it isn't the LT1. With only 40 psi, if the piston isn't at TDC it spins the crank. LOL,,,,,,,LOL,,,,,,LOL,,,,,LOL!
Actually, it doesn't matter if the crank spins, all of the valves are closed because the rocker arms are removed.
But some of the others are like a lever that push down on the top of retainer to release the keepers , if you are using one of those I would spin the crank if you are worried about dropping a valve
I have 20,000 on my new engine so i am probably going to be doing the same soon
Good Luck ,
Dave
