GM Issues Recall on 2005 – 2007 Model Year Corvettes
By -
2005 Chevrolet Corvette C5
If you own a 2005 – 2007 Corvette, take note: General Motors has announced a recall that covers 111,889 Corvettes from those model years for potentially faulty low-beam headlamps.
The recall also includes Corvette models from 2008 to 2013, which will be covered under a Customer Satisfaction Program, according to an official company press release. The company says all repairs will be at no cost to customers.
The official release for the recalled models states that when the car’s engine is warm, “the underhood electrical center housing could expand, causing the headlamp low-beam relay control circuit wire to bend.” If the wire is bent repeatedly, it can fracture and separate, causing the low-beam headlamps not to illuminate. “As the housing cools and contracts, the low-beam headlamp function may return,” the release says.
Apparently, the issue does not affect the the high beams, turn signals, marker lamps, fog lamps or daytime running lamps.
The Corvette recall is part of a sweeping safety recall announced today by GM that covers various issues that impact a total of 2.7 million vehicles.
GM says it isn’t aware of any crashes, injuries or deaths as a result of the recall issues tied to the Corvette, but to be safe, contact your local Chevy dealer if you own a C6 Corvette, so you can make sure your next cruise is a safe one.
Head to the Forum to Discuss this Recall >>
