needs some advice on safety gear (3 layer suit, gloves, showes,etc)
Old 12-15-2009, 01:14 PM
Z06_BluByU
Z06_BluByU's Avatar
Default needs some advice on safety gear (3 layer suit, gloves, showes,etc)
need advice on 3 layer driving suit, gloves, shoes, etc.. any tips or recommendations would be really great.. for running a few LeMons races and of course the occasional HPDE's
Thinking along these lines
[Suit:]
OMP Tecnica Light Suit
http://www.winecountrymotorsports.co...roducts_id=261
[Gloves:]
Sparco Wind
http://www.winecountrymotorsports.co...roducts_id=645
[Shoes:]
Puma Future Cat Hi Pro P)
http://www.winecountrymotorsports.co...roducts_id=314
[Undies:]
Sparco Carmyth Open Eye Balaclava
http://www.winecountrymotorsports.co...products_id=43
Sparco Nomex Boxer Shorts
http://www.winecountrymotorsports.co...products_id=66
Sparco Soft Touch T-Shirt
http://www.winecountrymotorsports.co...products_id=50
donno if the undies are overkill with a 3-layer suit.. doing a few lemon's races and some HPDE's.. just figure i wont mind having it if i'm ever in a fire...thoughts.. comments?!??!
Old 12-15-2009, 07:55 PM
Racer2B
Racer2B's Avatar
What size shoe are you? I've got a pair of PUMA's i'm selling for a friend:
http://forums.corvetteforum.com/auto...oes-175-a.html
You don't need all that expensive gear, especially the underwear stuff, which is not even required for a 3 layer SFI 5 suit.
Do you have any budget in mind you'd like to stay within?
Old 12-15-2009, 09:02 PM
Z06_BluByU
Z06_BluByU's Avatar
46.. close...
hows the suit and gloves?!?
Old 12-16-2009, 07:54 AM
AU N EGL
AU N EGL's Avatar
http://www.discoveryparts.com/ provides discounts to NASA members
This time of the year there are discounts on end of the year run or out of style designs.
No need to spend mega $$ on a suit.
G-force makes some fine equipment. Even some custom made suits for several forum members
Old 12-16-2009, 09:45 AM
ScaryFast
ScaryFast's Avatar
Saferacer always has closeouts on suits. You can save a TON. Nomex technology hasn't changed much in the last few years...
Old 12-16-2009, 09:57 AM
Z06_BluByU
Z06_BluByU's Avatar
yea.. been finding some nice high end suits under $1k.. what are your thoughts on the quality, weight, breathing characteristics and mobility of that suit (and others)? It gets pretty hot down here in the summer, so something lightweight would be nice.. trying to max protection while not getting bulky or hot. it seems worth some $$ to keep myself cool, mobile and protected.
Old 12-16-2009, 10:02 AM
AU N EGL
AU N EGL's Avatar
It will be very very HOT.
May want to also look into a "cool" or "fast" cooling system
safe racer http://www.saferacer.com/auto-racing-suits/?cat=53
Old 12-16-2009, 10:24 AM
Racer2B
Racer2B's Avatar
You can even get a custom suit built by some places for under $1k, 2 layers, SFI 5 rated.
Also, the PUMA shoes, size 45 in PUMA is about 11.5US according to SUBEsports sizing chart for PUMA's.
Old 12-16-2009, 10:36 AM
Z06_BluByU
Z06_BluByU's Avatar
interesting.. when i tried the 45's on the fit great.. but im not an 11.5.. maybe an 11.. mmmmm..
As for the custom suit.. i checked out your website and say that.. they suit i was looking at is 3 layer.. many of the 2 layers i looked at were heavier and bulkier than that 3 layer suit.. but thats thinking more's law (more is better).. is there an advantage to 2 layer?
Old 12-16-2009, 10:39 AM
Z06_BluByU
Z06_BluByU's Avatar
pretty high tech!!
Old 12-16-2009, 10:42 AM
Racer2B
Racer2B's Avatar
The coolshirt type systems are great, and there is a new system from 986 that's very innovative.
2 layer suits are sometimes heavier b/c you need thicker materials to get the same SFI rating, but if a lightweight nomex is used and it constructed so it won't bunch up in areas, it can be quite a bit lighter.
Definitely use whatever size fits, charts are just words.
Old 12-16-2009, 11:27 AM
Z06_BluByU
Z06_BluByU's Avatar
so 2 layer and 3 layer suits have the same fire rating?!?
Old 12-16-2009, 01:33 PM
Racer2B
Racer2B's Avatar
They don't always, but they can. Its all about the suits construction and how it was certified by FIA/SFI.
Old 12-17-2009, 10:36 AM
ScaryFast
ScaryFast's Avatar
Basically, once you get to a certain fire rating (SFI 5 as required by NASA and SCCA), the more expensive suits are just more comfortable. I found a couple of really really nice suits right around the $1000 price point. I really liked the Sparco X Light and Tech light suits. I ended up with a slightly different one (Sparco Super speedway, but it's discontinued) for two reasons - it fit me better and it was a little cheaper since it was a closeout.
Old 12-17-2009, 01:37 PM
Racer2B
Racer2B's Avatar
It really is very important to try on suits, as the sizing is not only different from brand to brand and model to model (even within a brand), but the designs are using different cuts, and for different body types. Just because you are 5'9 and 170lbs doesn't mean you'll fit into whats on the chart...you might have really long legs or something.
Old 12-17-2009, 02:31 PM
Z06_BluByU
Z06_BluByU's Avatar
Roger..
Old 12-21-2009, 08:47 PM
Racer2B
Racer2B's Avatar
Any luck finding anything? Let us know what you go with.
To needs some advice on safety gear (3 layer suit, gloves, showes,etc)
Quick Reply: needs some advice on safety gear (3 layer suit, gloves, showes,etc)
