Can a harness be re-certified? Where? (Sparco/Schroth)
Old 12-06-2011, 08:16 PM
travisnd
travisnd's Avatar
Default Can a harness be re-certified? Where? (Sparco/Schroth)
I have a set of Sparco/Schroth harnesses that expire end of this year. They are in perfectly good shape. Can I get them re-certified? Where? What would the approximate cost be?
or
Should I go ahead and buy new? I'd really like belts with pull-up lap adjusters.
Old 12-06-2011, 08:58 PM
eogel
eogel's Avatar
Very interesting question. I have never heard of recertifying belts. That may not be doable because of the effect of sun light on the material. From a cost perspective, it may not be worthwhile due to shipping + a certification fee.
Old 12-06-2011, 09:06 PM
johninar
johninar's Avatar
I had my Crow harness re-certified last spring. They reused the hardware and replaced the webbing. I doubt if anyone would re-certify without replacing the webbing.
Crow will only do their own harnesses.
Old 12-06-2011, 10:05 PM
Jason
Jason's Avatar
CI 4-5-6-7 Veteran
The webbing deteriorates with age, and especially exposure to sunlight. Just like the plastic parts under the hood get brittle with age and exposure to heat, so does the webbing on your belts. They may look perfect, but chemically/structurally they've changed.
Old 12-06-2011, 10:06 PM
RC45
RC45's Avatar
How much cheaper was that than just buying new belts?
Old 12-06-2011, 10:26 PM
travisnd
travisnd's Avatar
10-4... figured since the car is garaged/covered most of the time they'd have little UV exposure.
Old 12-07-2011, 01:03 AM
BERETTA
Support Corvetteforum!
BERETTA's Avatar
I just had my Team Tech Jet Pilot Harness re-certified. I sent it back to them, as said above they reuse the hardware but all of the webbing was replaced. Plus they charge extra to taper down the shoulder harness to 2 inches wide where the hans is. I only saved about $50.00 recertifying great service though turned it around to me in 10 days
Old 12-07-2011, 05:52 AM
varkwso
varkwso's Avatar
Since only hardware is reused savings are limited to that. I need a better harness for the Hans also. I have probably 5 sets of expired belts. Need to toss them I guess.
Old 12-07-2011, 06:33 AM
AU N EGL
AU N EGL's Avatar
Do not the belts stretch each time you tighten them ?
Old 12-07-2011, 06:51 AM
Jason
Jason's Avatar
CI 4-5-6-7 Veteran
Sell them to Mustang racers. How good do your belts have to be to sit on the side of the track and wait for a tow?
Old 12-07-2011, 07:13 AM
AU N EGL
AU N EGL's Avatar
Old 12-07-2011, 07:59 AM
davidfarmer
davidfarmer's Avatar
Crow charges $50 to re-web. The also have FIA taper harnesses for a good price. I used them in a customers car recently.
Old 12-07-2011, 08:16 AM
drivinhard
drivinhard's Avatar
When one died and sat the rest of the session on the backstraight in DE, my student couldn't figure out why I kept laughing.
Old 12-07-2011, 10:44 AM
PA Z06
PA Z06's Avatar
Good one
To Can a harness be re-certified? Where? (Sparco/Schroth)
Quick Reply: Can a harness be re-certified? Where? (Sparco/Schroth)
