Gold paint for headlight acuators.
where can I get the gold paint for the headlight actuators on my 72. The guy painted them black before I bought the car.
Rescue Rogers (10-16-2016)
Received 2,878 Likes
Hi 540,
You can duplicate the look of the original chromate washed zinc finish on the actuators fairly well by first spraying them silver, then DUSTING on some gold or copper levying bait of the silver peaking through in a few places. You can then DUST on some blue and green in even fewer places to mimic the iridescent appearance one the chromate wash.
Regards,
Alan
I think it does a nicer job for a bit less $ the the Eastwood kit.
This is the same finishing procedure used on the headlight door actuators.
Regards,
Alan
540 vette (10-18-2016)
oldsmobile gold
At a car show i was looking at a early 60's olds mobile. the gold valve covers looked sort of close. anyone else look at it?
Hi FR,
No not at all!
The fellow in Texas (probably Bob Demmel?) does really good work! And, is a nice guy too!
Regards,
Alan
No not at all!
Regards,
Alan
If you spend money to get them yellow chromate plated, you need to put a clear coat on them, too. Otherwise, in just a few years, they will be dull zinc colored again. Yellow chromate disappears due to oxidation (just being in air) rather quickly. The chromate is just a "wash" dip on zinc plated parts. It won't last.
Everything is a matter of 'cost vs. results' when you attempt to bring an old vehicle back to life. Getting stuff zinc plated and yellow chromate dipped so you can have "perfect" appearance...for a few years...is expensive. Buying a few cans of spray paint for doing most of your yellow chromated parts is [relatively] inexpensive and lasts for many MORE years. So, it's a 'choice' for the car's owner...
Hi 540,
Hi z,
Your results look very good!!!
You hit the nail on the head…. since the actuator is first plated with a layer of zinc and THEN the transparent dichromate 'wash' is done, you get a good duplication of the original plating with silver and then a dusting og gold or copper.
Regards,
Alan
Regards,
Alan
Hi 540,
Regards,
Alan
Regards,
Alan
Any specific blue and green. semi gloss, flat?
Hi 540,
It really doesn't matter.
You really only add a DUSTING of the blue and green to mimic the iridescence of the original dichromate wash.
Based on the car I THINK you're building, I don't think I'd even fool with the 2 colors…. just silver first and then a VERY light coat of gold or copper.
As z's photo shows it's good to see just a bit of silver peeking through when you're finished.
Regards,
Alan
Regards,
Alan
