Would seriously appreciate your thoughts...
I have to agree with Brian and a lot of the other posts. I am having some birdcage repairs done to my car in conjunction with a lot of other work and would estimate that just the rust repair cost me about $5k. It is costing me less because everything else is already being removed as part of the initial process. Most estimates I heard from forum members with near the $10k mark and it could be more.
You could keep the car if you really wanted too but with everything else going on I think this vehicle could add a lot of unneeded stress to your life. Car could be fine, but it might not be and you need to ask yourself if you can really afford to keep it right now. Additionally if it stays outside in the elements it will just get worse and lose more value. Post some pics of the area behind the kick panels and people can give you some more feedback on its condition.
Ultimately I would recommend you either move it to dry storage or sell it. Use your current funds get something more reliable and then come back stronger down the road.
wcgreen (12-08-2016)
Sorry to hear about everything and I can sympathize. The world is in absolutely no danger of running out of Corvettes in the next few years. Get rid of it. These things are money pits even under the best of circumstances.
At the risk of sounding trite, things really do get better.
i am somewhat of a pessimist when it comes to rookies buying corvettes and later asking for help regarding rust. I did the same thing, but got lucky and broke even after owning the rust bucket for 14 years.. so lots of folks make the same mistake.
you have received good advice regarding selling the car and wait for future positives in order to get a better one.
one's first classic car is usually a big learning experience and a headache to boot...
the first thing you need to do it get some money in the bank for your future.. classic cars are for those that can afford it.. not for those that have nothing but.. if you don't know how to work on it, then it is a formula for failure and will constantly keep you from getting ahead by giving all your money to mechanics, not to mention the downtime, and shoddy repairs... you won't own the car.. it will own you.
when a 39 year old car is leaking at the windshield area, it is a sure sign that there is extensive damage in the windshield frame, birdcage and frame. sure, you can throw a couple of tubes of caulk at it, but a correct repair will cost more than the car is worth.
Update
Thanks for all the advice, either way. Wanted to post an update. Will pull the kick panels later today to take pics. I DO have access to covered parking at my apt. and at school. I was going to move to a house with a garage when my wife joined me, but that will not be happening. So, I have covered parking for another year and a half.
I went out just now, and took a flashlight. It's very dark in there so I wanted to get a good look at the outside, through the glass, down the rails to the dash, and a the top of the frame, looking at that thin gap that is visible.
All the way down both sides and into the corners of the dash, it is smooth, black and clean. At the very top, the glass is rusty and hazy. This is just from a few inches in from the corner of each side, and across the middle.
Will pull the kick panels later to get a look. If this is any indicator, I am hoping they are clean.
Does this change any opinions?
Thanks again!
B
Thanks again!
B
That's the way they do things in AL.
OP, unless you can bicycle everywhere you need to go, then you might have a plan because your car is going to be out of commission for a year or more. Second, 5k is not going to get you very far in getting this done.
My advice is to sell the car and buy a nice little Toyota that isn't going to leech every dime you have. After you graduate and have a real job then buy another car then.
these old Corvettes were never designed to last 30+ years. Wiring, vacuum lines, bushings, body mounts, suspension components, weather stripping, etc. all eventually require attention. Most C3 corvettes I'm familiar with require regular infusions of cash unless they've been restored.
..put it in "dry dock" and work on it as the funds are available and use the money you were going to spend on the car to purchase a daily driver.
MajD
MajD
As recommended before - you NEED to pull the kick panels off. Take some pics and post here. Unfortunately, based on your description, I think most of us know what to expect, and its not going to be good.
Not trying to be debbie-downer, but the last thing you need is more "bad things" and mishaps. Once you spend your $5k to repair the winsdshield frame, what happens when the trailing arm bushings go bad, or the rear wheel bearings (on these cars is $$$ & time!!) Just sayin'
Good luck.
It is possible that when a replacement windshield was installed, it was not shimmed correctly and a gap was left that should not be there. That would allow the water to get into the windshield frame area and into the interior. Obviously, if that is the case, the windshield frame would be rusted...the extent of which is unknown, except for the pieces of rust coming in with the water.
You could have a windshield installer (ie, Safelight Auto Glass) come to re-install your existing windshield properly, in hopes that a good install would reseal everything. That would be another 'fingers crossed' action, and success may not be the outcome. But, success is at least possible. You would need to call and fully explain the circumstances (the car, not your personal issues) and your expectations. And, it might cost you about as much as if you got a new windshield installed. If this is successful at sealing the birdcage and interior, it would allow you to keep using the car as your daily driver.
P.S. It is not uncommon for a glass replacement company to install the C3 windshield improperly. There are special spacers required to position the glass properly; and there are seals in the stainless steel exterior covers that need to be replaced/repaired when that job is properly done. Make sure you discuss those needs with whoever is contracted to do that work.
Billy
Update
OK- removed the kick panels and door sill trim. It appears worse to me in the picks than viewing. What you see is either surface rust or loose bits on both sides. The areas show are all solid and no holes. Tapped it well... majority of stuff has fallen from above clearly. As I said before, I took a flashlight and followed all down the exterior looking and the metal you see through the glass on the pillars is black and no visible rust. You only see some rust fogging the glass at the center top and going to each top corner. So, thoughts?
host image online
free upload pictures
host image online
Can you afford to buy a cheap daily driver and keep the 'Vette for nice weekends? You are single now, it's a lot easier for a 52 year old man to pick up women in a 'Vette than a Toyota...That's why I got mine.
Received 2,878 Likes
Hi Billy,
Quite a tale of woe!
Putting what you describe as your last $5000 in a 37 year old NEEDY car doesn't make much sense.
I agree that using that money to buy a car that you can depend on DAILY might be the first step in getting your life under control.
It seems to me that this would be the adult decision!
Sorry!
Regards,
Alan
Sorry!
Regards,
Alan
#33
Received 1,469 Likes
Cruise-In II Veteran
Richard Daugird (12-07-2016)
#35
Received 2,686 Likes
In 2008 my airline pilot career came to an end with the collapse of DHL in the U.S., that major collapse in my life resulted in a divorce from wife of 25 years. I had just bought my first Corvette, after a long life of wanting one. On my birthday of that year, I watched as the guy I sold the project to drive away with the car on a flatbed. The following year and a half were a further spiral decline in my life.
Eight years has passed since then. I have a new wife, a new career in aviation that is more secure than flying airplanes, and I have bought and restored my 77 Corvette.
Life can turn, and you just have to keep trying, but sometimes you have to take a step back before you can move forward, AND believe that better things can happen. They did for me, and I never believed it would happen till it did. Consider that.
#36
Sounds like you have a lot of challenges to deal with. I think you are an intelligent mature individual, able to get over these hurdles. You are on a tight budget, working on your degree, living in an apartment, going through a divorce. I understand your love of the C3 Vette. What a beautiful car! My favorite! But a 40 y/o Vette, is like a high maintenance mistress. Fun on a sat night, and needs her own apartment. Let this one go. Get your degree, a simple reliable mode of transportation, put the divorce behind you. Hope you get a job you enjoy, get a house with a garage, and study Vettes! Good Luck Sir!
#37
I appreciate all the thoughts and input. There is a shop inMobile where I am from- they did my brother in law's frame off resto of an old Ford pickup. Just did a Vette this year. They are gonna look it over for me over the holidays if I take it down. Their thoughta are the same- sell it if it's as bad as they think- question? Can you find a C3 in this kind of mechanical and cosmetic shape with no birdcage rust for 10k? If so- lots of searching or common? Im just worried it will be tough to sell this one as Thera no title now that AL doesn't title vehicles this old.
#39
You will have no trouble selling it in Alabama. Having no title for a car is common down there.
The kickpanels don't look as bad as I expected them to be. However, if the car was not regularly garaged...and it allowed water to get into the birdcage area often, the windshield frame could be "toast". Nice that you have some folks that can check that out for you. Since they will need to remove the SS fascia moldings off the w/s frame to look at its condition, could they arrange to properly re-install the windshield at that time? Even if the damage is more than you are willing to accept, having the w/s installed correctly will prevent water from getting into the birdcage and the interior, and it will be much easier to sell. And, if the damage is NOT too bad, that may just allow you to continue using it as your daily driver.
#40
