What are the symptoms of heat soak?
Old 05-03-2006, 04:37 PM
7Deuce
7Deuce's Avatar
Default What are the symptoms of heat soak?
Could somebody explain what symptoms a car will exhibit if it has starter heat soak. Will the car crank at all? How long does the starter have to cool before the engine will crank? Any other common traits?
Appreciate any info.
Old 05-03-2006, 05:18 PM
79Cruzer
79Cruzer's Avatar
I had this on my '79 for a few years and finally corrected with a new mini-starter. I have not had one problem since. The mini-starter was only about $90. The symptoms for my heat soak problem were... If the car was running for more than 15-20 minutes and I shut the car off it would not start for about 15 minutes. If I tried to restart the car it sounded like the battery was very low charged and could hardly turn over. I tried the heat shield wrap that you can buy, but it didn't work. For my application, a new starter was the quickest route. Someone here on the forum suggested replacing the spring in the solenoid which probably would have worked but I'd had enough and decided on the new starter. Hope his info helps.
Old 05-03-2006, 05:41 PM
7Deuce
7Deuce's Avatar
so the engine will try to crank albeit very weakly?
Old 05-03-2006, 05:43 PM
79Cruzer
79Cruzer's Avatar
Yes. That was the case with my car.
Old 05-03-2006, 06:26 PM
Eddie 70
Support Corvetteforum!
Eddie 70's Avatar
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
The 79 I used to have exhibited the same conditions that you describe. I installed a new solenoid on the starter and it fixed all of my heat soak problems.
Old 05-03-2006, 06:49 PM
grimis
Navigator
grimis's Avatar
Default go with a mini....
A mini starter is the way I went with my 79 aswell.
No problems since.
Peace!
Old 05-03-2006, 06:51 PM
StickShiftCorvette
StickShiftCorvette's Avatar
My heat soak experience is that the engine wouldn't crank at all. When it happened the amp gage pegged negative.
The mini-starter cured mine on both of my small blocks......
Old 05-03-2006, 06:53 PM
Terrordome
Terrordome's Avatar
I have the same problem with my 74. It is almost embarassing at the gas station when I pull in and everyone turns to look at the car to see what is making all that noise then when I go to start it sounds like it is on it's last leg. Glad to read it is a common and how to fix.
You guys are awesome.
Old 05-03-2006, 06:55 PM
7Deuce
7Deuce's Avatar
This is exactly what is happening with my car after long drives, won't crank at all and when I turn the key amp gauge pegs negative. I'm trying to determine if it's an electrical problem or possible a heat soaked started. Question: why does the amp gauge peg negative?
Old 05-03-2006, 06:59 PM
Edzred72
Edzred72's Avatar
Had the dreaded soak on my 77 with headers. Heat blanket didn't work. The NCRS board suggested cutting 1.5 coils off the soilinoid engage spring. Worked like a charm for me, and didn't cost a thing.
Eddie
Old 05-03-2006, 07:41 PM
rosslato
rosslato's Avatar
had the same prob on my 73, it's embarrassing to say the least, got a new starter and a starter shield(stainless) and never had that prob again.
Old 05-03-2006, 08:38 PM
mrvette
mrvette's Avatar
OK, lets just say there are electrical folks who know what in hell if happening and those who beleive in 'heat soak'.....
first case, when I buy ANY used car, I find the battery cables and grounding from engine to frame,...rubber mounts ring a bell?? so therefore there needs be a heavy ground from BATTERY, like through the FRAME to engine on the negative side, and sure enough that heavy thick cable to the starter large stud comes right from the positive post....
you get a negative on your 'ampmeter' you got a large enough grounding problem through the frame....
so pull off the connectors, grind the metal clean, polish all the star washers, tighten tite as hell, and then cover with RTV rubber silocone sealant....water tight for damn near ever....
especially if you coat the bolt threads when hammering home into the frame...can't get in throug the threads then....
my car was fixed as so many others through the years/decades just eh same way....
GENE
Old 05-03-2006, 08:47 PM
aussiejohn
aussiejohn's Avatar
Default heat soak
Vette Rx,
I had a similar problem with the 308 V8 Holden engine in my Commodore. It's not dissimilar to a Chevy small block. I had just fitted a reconditioned engine to the car and took it for a drive. The timing must have been retarded and I got stuck in traffic at a stop light. Foolishly I shut it off ( to stop the heat rise ) and when the lights went green it would not start. After a few minutes, I remembered something I had read about pouring water on the starter. I pulled the line off the windscreen washer bottle and sprayed it on the starter for a minute or so. Then I hit the starter and it fired right up and I drove home.
I am not suggesting that this is any sort of a permanent cure but it should get you out of trouble in a pinch. The problem is the heat radiated off the block and the cast iron exhaust manifolds. Tubular headers will dissipate heat a lot quicker than cast iron manifolds but there is still the heat from the block. A heat shield around the solenoid is the cheapest cure, but carry a litre bottle of water and a few feet of plastic tubing with you just in case.
The Corvette has headers and I don't have a problem with it.
Regards from Down Under
aussiejohn
Old 05-03-2006, 10:43 PM
DollaGreen
DollaGreen's Avatar
hmm....
Albeit may be an odd, archaic-sounding verbal flourish, but as a conjunction it has been flourishing since Chaucer's time. As you imply, it literally means 'all (completely, entirely) though it be'. The actual meaning of albeit is closer to 'even though or even if; although (it be)', and just like although, though, it is sometimes used to begin a clause: "He can ask for a loan, albeit I do not think he will get it." Here albeit implies an opposition or contrast, and yes, it is very similar to but.
However, the Albert Einstein quote shows the more common use of albeit in a concessive phrase," one that expresses some sort of conceding, yielding, or admitting. In this use albeit can mean 'conceding or admitting that; in spite of the fact that', and the word notwithstanding can sometimes be substituted.
In the word albeit, the verb "be" is the third person singular present subjunctive. (The corresponding indicative form would be "is.") In subjunctive constructions, the order of subject and verb is sometimes reversed: "Be it ever so humble...; Be it feast or famine..." (Patrick Henry's exclamation, "If this be treason, make the most of it," is an example of a subjunctive construction in which subject and verb are in the usual order.)
Historically, the adverb all has been used with the conjunctions if and though, and often the order was reversed, producing "all if, all though." The phrase "all though" was originally an emphatic form of though, which later became although. Sometimes the conjunction if or though was dropped if the verb was placed before the subject, leaving all as an apparent conjunction, in the sense of "even if, even though, although." So the phrase "al be it" meant 'although it be', which later became the one-word form albeit.
ahem...oh sorry...didnt know what that meant...had to look it up...and pick on the poster as I know him personally, and found it odd he used a word so exiguously heard in common speach.
Old 05-04-2006, 07:38 AM
7Deuce
7Deuce's Avatar
Tried to start my car last night after it had sat a day and cooled off. Car cranked strong and fired right up. Looks like I'll have to try some of these fixes with the starter since I think that's were my problem is.
Old 05-04-2006, 07:43 AM
7Deuce
7Deuce's Avatar
Originally Posted by DollaGreen
hmm....
Expanding the vocabulary of the forum one word at a time...that's my mission
Old 05-04-2006, 08:41 AM
69'Silver
69'Silver's Avatar
Eddie
I have the same problem. Replaced the solenoid last fall, but it still needs to sit after a run before restarting. Can you explain a little more as to what coils you cut. Is it the coils on the spring?
To What are the symptoms of heat soak?
Old 05-05-2006, 01:37 AM
BLUSHRK
BLUSHRK's Avatar
I have that same problem! Ahhhh! Stuck in a parking lot for 1.5hrs... could someone please post directions on how to shorten that spring??? Much abliged...
Old 05-05-2006, 04:03 AM
ETM
ETM's Avatar
My Vette would have heat soak after mutiple stops say {running errands} in the summer.It wouldnt crank at all...usually after 10-15 it would then fire up...I went out and bought a new starter..Its been OK since about a year and a half.
Old 05-05-2006, 04:21 AM
Jughead
Senior Member since 1492
Jughead's Avatar
Location: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
hmm....
Thanks Professor. That was superkalifragilisticexpeealidosis!
Quick Reply: What are the symptoms of heat soak?
