Seat Removal in 75
Seat Removal in 75
I need to remove the drivers seat because the back is locked into position and can't move it. I also need to get a new seat since the back of it needs alot of work. What is the best way to get these seats out?
-Frank
Thanks for the replies. It is starting to look like a 2 person job. One under the car and the other on top the car. The seat does go forward and backward but the back support is what is stuck. I also need to get the whole seat recovered.
Three of the nuts will not turn as they are welded to a plate. the back outside corner may have a nut that you can hold while loosening the bolt. One man 5 minute job.
Eddie
Suggestion 1: apply penetrant or oil to the exposed bolt threads under the car. On most cars, they'll be rusty and you don't want to break the weld nuts loose.
Suggestion 2: wrap duct tape or such around the corners of the track before you remove the seats -- or be very careful. The tracks will chip the paint on the doors jams with any contact.
Two things: In my 78 I had new foam and the very best "pleather" installed, cost me 700.00 cdn funds at a local uphostery shop.
SHOP your quote, The guy who did mine was less than half of the other quotes !
Now the seats, both seats one man 5 min.
Move seat all the way forward, 1 bolt each side, move seat all the way back 2 more. That simple, takes as long as removing spark plugs. (there should be no welded bolts)
If ceased even wd40 will be enuf.
Good luck.
Good luck.
Did ya get the seats out? Wanted to chime in as I just finished recovering and rebuilding both seats in my 1970. The seat back will not move forward b/c the latch is most likely broken at the top or just frozen.
Once you get the seat out, push on the latch at the top... does it move? If it does and the seat back will not move forward, you will need to take the upright part of the seat apart. The latch system needs to be accessed.... UNDERNEATH the cover. It is actually it's own individual assembly in a track. Four little bolts hold it in place. However, you will not be able to slip it by the cover easily...
Let me know if you need a full walk through... it is not difficult but not exactly for a beginner, which I am guessing b/c you inquired about the seat bolts.
I haven't had a chance to take them out yet. By the time I get home from work, it is after 6:30 then make something to eat then work on customers computers for the next few hours. About the only time I have to work on anything is on the weekends. I hope I can get to it this weekend since I have to take a couple of trees down in my back yard. That is why it takes me forever to get something done.
Received 1,469 Likes
Cruise-In II Veteran
