1979 lower radiator hose spring
Old 01-16-2010, 11:03 PM
mint79
mint79's Avatar
Default 1979 lower radiator hose spring
Guys- just what is the spring in the lower radiator hose for?
when the hose bends so it does not kink? Replacing my radiator
and hoses, new lower hose had no spring, destroyed the spring in the old hose trying to get it out.should have just cut the old hose apart.
Do i need it?-Thanks as always
Old 01-16-2010, 11:09 PM
bobs77vet
bobs77vet's Avatar
Location: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
you need the spring it stops the hose from collapsing and stopping all coolant flow
Old 01-17-2010, 08:53 AM
zigvs
zigvs's Avatar
Its the return side to the rad.it will suck shut and stop flow.you need the spring
Old 01-17-2010, 06:36 PM
bobs77vet
bobs77vet's Avatar
the spring is not particularly specific to the vette you can buy any hose that has the right size diameter and just pull the spring out and put it in the hose for the vette
Old 01-17-2010, 08:55 PM
7T1vette
7T1vette's Avatar
Received 2,713 Likes on 2,271 Posts
The 'stock' hose is a smooth surface hose that can go flat when it gets hot, as it is on the suction side of the water pump. Some new hoses are corrugated and don't need to have a spring...they won't collapse anyway. If you need a spring, see if you can find a stainless steel one. It won't rust away.
To 1979 lower radiator hose spring
Quick Reply: 1979 lower radiator hose spring
