Lifting Big Block Question
Old Jan 17, 2010 | 03:34 PM
Kim72's Avatar
Kim72
Default Lifting Big Block Question
I need to lift up my big block to change motor mounts. Can you jack from the oil pan?? If so, the front of the pan?? Looks like a lot of weight for this. I can't get a cherry picker in where is garaged. Any experience here??
Old Jan 17, 2010 | 04:37 PM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
It is a lot of weight (over 600#) and IMCO, you stand too great a chance of wrecking your pan, and then where are you? I know it's not what you were looking to hear, but if you can't bring the picker to the car, I'd take the car to the picker.
Old Jan 17, 2010 | 04:40 PM
brngrhd's Avatar
brngrhd
use your knees the back will give out
Old Jan 17, 2010 | 05:05 PM
roscobbc's Avatar
roscobbc
I replaced my engine mounts recently - but I did one side at a time, and yes I jacked the engine under the oil pan, but used a a 4" x 2" piece of timber to spread the load - it only needs to move a small amount!
Old Jan 17, 2010 | 05:06 PM
Alan 71's Avatar
Alan 71
Hi Kim,
I'd think you could use the jack with a tall 2x4 block that runs along the side of the pan to the flange of the block that the pan bolts to. Protect the lip on the pan so that the 2x4 doesn't bend it.
One side at a time?
Regards,
Alan
Old Jan 17, 2010 | 07:13 PM
Faster Rat's Avatar
Faster Rat
2024 C3 of the Year Finalist - Unmodified
Originally Posted by Alan 71
Hi Kim,
One side at a time?
Regards,
Alan
That's the way I did it.
Make sure your fan doesn't hit the shroud....
Old Jan 17, 2010 | 08:29 PM
jordan89's Avatar
jordan89
If I had a cherry picker available on site I would go the safe route and use that instead. This would save you from having to buy a whole new oil pan if you mess the oil pan up when jacking it.
Old Jan 17, 2010 | 08:31 PM
cardo0's Avatar
cardo0
From: Las Vegas - Just stop perpetuating myths please.
Default Trans mount?
U want to unbolt the trans mount too. I recall the trans will hit the tunnel at full lift. Not much room on my sb but they came out. Did my sb with a bottle jack and 4"x4" wood piece under the oil pan too.
cardo0
Old Jan 17, 2010 | 08:36 PM
tt 383's Avatar
tt 383
Use a piece of 3/16 plate, you could even contour it some to "cup" the shape of the pan.
Old Jan 17, 2010 | 10:18 PM
thatcorvetteguy's Avatar
thatcorvetteguy
I've used 2"X6" before with no problems
Kim72's Avatar
Kim72
Thanks to all. I got it done. Lifted one side at a time with a piece of 4x4.
To Lifting Big Block Question
