Rear Bumper Letter Install
Old 04-03-2013, 07:58 PM
rodney25
rodney25's Avatar
Default Rear Bumper Letter Install
Hi All,
I need to install the C O R V E T T E rear bumper letters. The letters did not come with screws or locking nuts for the back of the letters. Does anyone know how to install the letters on the rear bumper?
Old 04-03-2013, 08:10 PM
John 65
John 65's Avatar
Hi Rodney, You would use "speed nuts" for them.
Old 04-03-2013, 08:14 PM
John 65
John 65's Avatar
Old 04-03-2013, 08:19 PM
rodney25
rodney25's Avatar
Thanks, Do I use two for each letter or one for each letter?
Old 04-03-2013, 08:44 PM
johnt365
johnt365's Avatar
I used a little dab of this stuff on each post. Its for trim...
No fuss.
Just another option...
Old 04-04-2013, 08:15 AM
Alan 71
Alan 71's Avatar
Received 2,878 Likes on 2,515 Posts
Hi Rodney,
I'm not sure what year you're working on?
Through 73 each letter had 2 posts, and there were 2 holes in the fiberglass for each letter.
One post was short and was just used to keep the letter in alignment, while the longer post extended through the fiberglass and received the speed nut.
Regards,
Alan
Old 04-04-2013, 12:40 PM
Easy Mike
Support Corvetteforum!
Easy Mike's Avatar
Received 1,469 Likes on 1,248 Posts
Cruise-In II Veteran
Originally Posted by rodney25
...Do I use two for each letter or one for each letter?...
I agree with Alan. The longer, bigger pin on the rear of the letter gets a speed nut. The shorter, smaller pin only locates the letter and does not get a speed nut.
The 74 letters may be different and one year only. Check the 74 AIM.
Old 04-04-2013, 07:23 PM
7T1vette
7T1vette's Avatar
Received 2,713 Likes on 2,271 Posts
I believe that 'barrel nuts' were used sometimes. They just get pushed into each hole, then you press the letters/pins into the barrel-nuts. They work like a Chinese finger 'handcuff'...you can push it in with no problem; but it tightens more when you try to pull it out.
I have seen them advertised in the Original Parts Group parts catalogs (www.opgi.com).
Old 04-04-2013, 09:36 PM
rodney25
rodney25's Avatar
Now that makes sense. For a minute I thought the vendor did not pack the correct number of nuts. Perfect thank you all for the priceless info.
Thank you.
To Rear Bumper Letter Install
Quick Reply: Rear Bumper Letter Install
