shim distance in distributor.question.
Cruising
hi guys
i take out my distributor and i found that i have only one shim (B) in the gap between the body of distributor and the gear wheel.
the gap looks in my eyes to big and i couldnt find what is the correct space between them. (A in the attached photo).
i found in corvette central part no 727148 kit of shim but with 5 pieces of shims.
http://www.parts123.com/parts123/yb....rt~A2~cadefibG
ill be glad if someone knows what is the proper gap\space (A)
thank you in advance
You took out your distributor; and you also took it apart. But, when you put it back together, you installed the drive gear upside-down. Remove it, put gear toward the dist body, re-pin it....then check for clearance. It will likely check differently.
For setting shims, only install the pin far enough to engage the two pieces (so that you can easily remove it again, if shims need changing). I believe the proper amount of clearance is around .002-.005" [.05-.12 mm].
OK. Go with Lars' suggestion.
Location: At my Bar drinking and wrenching in Lafayette Colorado
Received 4,926 Likes
Use Moroso part number 26140 for the shim kit.
Be sure to put the gear on the right way (it's upside-down in the photo) with the dimple pointing the same direction as the rotor firing tab.
Lars
I took mine apart and I don't know if it is like this or not. Don't want to pull it if I don't have to. Seems to run fine now. I guess there is a 50/50 chance it's right?
This is important to make sure the rotor is aligned precisely with the cam gear teeth. If the gear was oriented 180* out, this will change the relationship with the rotor and cam by exactly one half tooth.
The ONLY difference this makes is with the position of the distributor housing when setting timing. Many owners find that they can't set timing without the housing hitting the intake manifold or coil bracket.
Not the most obvious detail to see when building an engine or the easiest concept to understand.
Another "subtle" item is that the distributor hold down bolt and clamp also perform the job of transferring electical ground to the dizzy. Many folks clean all that stuff up and paint it when they work in that area. But, don't put paint on the bottom side of the clamp; also, make sure the contact points of that clamp have bare metal under them on engine block and dizzy shaft hub.
{It's really annoying to fix all that stuff up and then have it NOT start.}
The distributor gear is not drilled symmetrical: If you look at the drilled hole for the pin, it is aligned with a tooth "ridge" on one side, and a tooth "valley" on the other side. Putting the gear on one way or the other will change the distributor's installed clocking by one tooth. This is enough that on some Vettes, with the raised manifold rear runner and with distrubutor shielding, that the timing cannot be correctly set, because the vacuum advance can will hit the manifold runner before you get the timing right. That's why the dimple is there: to set the gear aligned with the rotor tab so the distributor will be correctly "clocked" in the block when the timing is set.
If there is no interference, the timing can be set just fine with the gear on backwards. The distributor clocking just won't be visually "correct", so people like me will look at your engine and say, "Hey - your gear's on backwards and your distributor isn't clocked right." And then you say, "Yeah, I'm just too lazy to put the distributor in the engine the right way."
