C3 5.3L Truck Motor Swap
Old 01-01-2016, 03:27 PM
JGoodin86
JGoodin86's Avatar
Default C3 5.3L Truck Motor Swap
I just wanted to share my recent ls swap on my 81 corvette.
I started with a 2001 5.3L Silverado motor, harness, computer, and accessories. Removed the fan, a/c, intake, oil pan, and exhaust manifolds.
I used a Hughes trans adapter and ovaled out the flexplate holes since I am bolting it up to stock th350 trans. I bought some billet motor mount adapters off eBay.
I have stock steering and used the Fbody oil pan, pickup, and windage tray. I also just cut down the truck oil dipstick and bent the tube a little to clear hood.
I used fbody exhaust manifolds and tapped the water pump outlets for some 90 degree street brass fittings from ace hardware. Then bought some dorman heater connection for the hoses. I did have to clearance the aarm a little to make more room.
I used all the truck accessories. Water pump need the straight thermostat housing. Power steering pump fit great. Just cut the return tube a little and the pressure line was actually the same threads as my stock line.
Now for the alternator. I cut the bracket in the normal place to clear the ls1 intake. I then cut alt bracket from bottom of the alternator straight down and over to the top of the power steering pump. Leaving the three main head bolt holes alone. I then made a brace from the lower right head hole to the outside alt hole. I relocated the idle pulley to the top alt bracket head hole. Just used a longer bolt from fastenal and some washers for spacer. Used a 101" belt, I think.
I installed a walbro 255 intake just hooked onto the stock pickup. Used a corvette regulator inside the frame below the heater and a/c housing. I used a lot of stuff from the stock truck fuel line and rail. Just flared the tubing. Found a flex hose for fuel injection. The ls1 fuel rail can be flipped around so the fuel port is on the passenger side. That is what I did.
I used stock ls1 intake and injectors. I used a stock truck throttle cable. Just cut the cable down a little and used a throttle stop kit from advance. I made a custom throttle cable bracket out of the stock truck one.
Installed a regular electric fan controlled by the truck pcm. I made a standalone harness using lt1swap website. I found the stock cel wire ground and connected the wire to my stock harness. Works great. I used stock maf and map sensor. I made a upper radiator tube with the stock temp sensor and a steam port fitting.
Air intake was out of some stuff I had laying around.
This was a very cheap and easy swap. Please ask any questions you have. Pm or text me 4172248528
The following 6 users liked this post by JGoodin86:
69L46vert (06-07-2017), ajrothm (05-29-2017), carriljc (11-27-2018), SH-60B (05-29-2017), xhartman (01-02-2016), Zero1Niner (04-07-2016) and 1 others liked this post. (Show less...)
Old 01-01-2016, 05:14 PM
tfi racing
tfi racing's Avatar
Cool,I always wondered if the was enough room in front of the engine to use the truck accessories,this is how I mounted my alternator,chopped down the truck mount and fabbed up a steel plate with an idler on it.
Old 01-02-2016, 01:15 AM
qwank
qwank's Avatar
Excellent work
Old 01-02-2016, 01:47 PM
worship79
Support Corvetteforum!
worship79's Avatar
Good job, thanks for the write-up!
Old 05-26-2017, 06:15 PM
him5211
6th Gear
him5211's Avatar
Default Alt bracket
I am not sure how old this thread is but was wondering if you could show pictures and go into more detail about the alternator bracket mod. i currently just installed my 5.3ls in my 78 and the alternator is sticking up really high
Old 05-26-2017, 08:49 PM
JGoodin86
JGoodin86's Avatar
I can't get any pictures, but i cut the bracket from the inboard alternator hole down to a lower outboard hole. The rotated the alternator down and ran a piece of 1" angle between the bottom hole and the outboard alternator hole. Then had to cut out some of the angle to clear the belt
Old 05-27-2017, 07:09 AM
holley505
holley505's Avatar
Nice to see more LS swaps. You should have changed the cam
Old 05-27-2017, 07:10 AM
JGoodin86
JGoodin86's Avatar
I have a 3800 stall, and am going to be getting Melrose headers and the Torquer v2 cam
Old 05-29-2017, 01:05 PM
george2066
george2066's Avatar
Default what is next?
bolt on supercharger, OD trans
I have that engine in my silverado, about 325 hp stock
The following 2 users liked this post by george2066:
jdog1woof (12-06-2019), jimminee2000 (07-27-2021)
Old 05-29-2017, 01:46 PM
JGoodin86
JGoodin86's Avatar
it has the 4l60e in it now. I will probably just cam and exhaust. Maybe ls6 intake
Old 05-29-2017, 02:43 PM
ajrothm
ajrothm's Avatar
Received 1,095 Likes on 746 Posts
What did you do for gauges?
Looks like a great budget swap with good power potential.
Old 05-29-2017, 03:06 PM
JGoodin86
JGoodin86's Avatar
autometer electric Speedo and tach. Stock center ones
Old 05-30-2017, 09:04 PM
Richard Daugird
Richard Daugird's Avatar
I was wondering why you didn't go with OD; now I see you did. How is the performance?
Old 05-31-2017, 02:46 AM
JGoodin86
JGoodin86's Avatar
a lot better on the highway.
Old 06-07-2017, 02:25 AM
stingraymaniac
stingraymaniac's Avatar
Great build, thinking of doing a similar transplant but with a 6.0 lq4 or lq9
Don't know if the accessories are the same on those?
Old 06-07-2017, 05:57 AM
JGoodin86
JGoodin86's Avatar
the accessories should be the same
Old 06-07-2017, 09:27 AM
cv67
cv67's Avatar
Received 3,043 Likes on 2,602 Posts
St. Jude Donor '05
truck intake works real good on the st
Wallowing out the holes on the flexplate can you elaborate?
To C3 5.3L Truck Motor Swap
Old 06-07-2017, 09:30 AM
JGoodin86
JGoodin86's Avatar
the th350 converter has a slightly different bolt pattern than the 4l60 flexplate.
when bolting a th350 to ls1 motor, you need a spacer and oblong the 3 bolt holes on the flexplate
Old 06-07-2017, 09:41 AM
75Stingray007
8th Gear
75Stingray007's Avatar
Nice!
Old 06-07-2017, 11:35 AM
cv67
cv67's Avatar
St. Jude Donor '05
how do you do programming to run the T350?
reason Im asking is id like to run a T400 behind my 02 Silverado have no clue how to make it work...these 4l60es are pieces of crap and not cheap.
Quick Reply: C3 5.3L Truck Motor Swap
