Stock 67 thru 72 Vette open element air filters
Old 06-25-2016, 02:31 PM
vetternr
vetternr's Avatar
Default Stock 67 thru 72 Vette open element air filters
Does anyone know if the stock open element air cleaner filters on the 1967 thru 1972 Vettes are all the same size in height. I have a 1972 LT1 air cleaner I am trying to use on my 454 Big Block that I installed the Holley Commander 950 Multi Point Fuel Injection system on. I have an L88 hood minus the cold air box so I have better hood clearance BUT still need 1/2" or more. The problem is the Air filter ( stock LT1 ) is 3" tall. If I could find the same air filter but not as tall it would work just great. Even 1/2" to 1" shorter would do the trick.
Old 06-25-2016, 03:23 PM
Alan 71
Alan 71's Avatar
Received 2,878 Likes on 2,515 Posts
Hi v,
I think 68-72 open air cleaners (single carb) used the AC 212 C filter. 14"x3".
I believe Summit shows 14" diameter paper filters in various heights from 2"-3".
Perhaps you can find what you need there.
Regards,
Alan
Old 06-25-2016, 07:33 PM
vetternr
vetternr's Avatar
Default Air Filters at Summit
Originally Posted by Alan 71
Hi v,
Regards,
Alan
Thanks Alan
I looked at Summit. They do show an AC212C. I did not see any where where the size was 2". The only one I saw was 3".
Al
Old 06-26-2016, 11:05 AM
7T1vette
7T1vette's Avatar
Received 2,713 Likes on 2,271 Posts
Check ebay for 14" round air cleaners filters with 2" height
Old 06-26-2016, 11:42 AM
Alan 71
Alan 71's Avatar
Hi Al,
Sorry.
I didn't mean to imply that you would buy a 212 replacement. I posted that to answer your question as to whether the typical original filter was 3". It was.
Summit appears to offer various 14" diameter filters that will look more or less original in heights less than 3"
Regards,
Alan
Old 06-26-2016, 01:52 PM
TWINRAY
TWINRAY's Avatar
I run a Purolator A60102 in my '69 with a ZZ4. It's 2.5" and gives me the 1/2" I need due to the ZZ4 manifold height increase over the stock 350/300 manifold height.
Old 06-27-2016, 02:24 PM
vetternr
vetternr's Avatar
Default Thanks all and comments
Thanks all for the responses. I will give the Purolator A60102 a try. I found a Mr Gasket 1480A which is 2" in height sold at O'Rielly. Still just a little too low however as the air cleaner lid will not fit.
twinray? Could you give me a few more details and pictures if you have some about the ZZ4 you installed. I'm kinda new to the ZZ line of engines and wonder how well it adapts ( replaces ) the stock factory small block ?
I have a crate motor in the 72 Vette I recently inherited. I was led to believe it is a GM Crate motor ( and it might be ) however the stamping on the front exactly where GM stamps them with the stamping 14 E 11353 Does anyone have any idea who the engine manufacturer of this might be ?
Old 06-27-2016, 03:08 PM
MCMLXIX
MCMLXIX's Avatar
I have the zz4 intake on my 69 sbc.
With the stock drop base air cleaner and qjet I run a 3 1/2" air filter with a small block hood.
If got rid of the thick carb base gasket a 4" filter would fit.
Old 06-28-2016, 08:45 PM
vetternr
vetternr's Avatar
Well I picked up a Purolator A60102 at Advance Auto Parts. With my Military discount it was about $10. Fits perfectly. It is 2.5" tall and solved my problem. Thank you all for your input and time to help.
Old 06-28-2016, 11:07 PM
BLUE1972
BLUE1972's Avatar
Received 1,130 Likes on 733 Posts
Auto Zone has both 2" and 2.5" in stock.
Old 06-29-2016, 05:36 AM
vetternr
vetternr's Avatar
Default Your 72
Is your 72 Bryar Blue ?
Old 06-30-2016, 12:03 PM
TWINRAY
TWINRAY's Avatar
I don't have the stock drop base assembly which constitutes my problem now that you mention it.
Old 06-30-2016, 03:37 PM
BLUE1972
BLUE1972's Avatar
is your 72 bryar blue ?
targa blue, # 979
Old 06-30-2016, 10:49 PM
vetternr
vetternr's Avatar
Default Color
targa blue, # 979
I love the Targa Blue. I also love the Bryar Blue. If you ever get a chance to do this --- Park your 72 Targa Blue Vette next to a Bryar Blue 72 Vette. The colors really CLASH a lot. My 72 Bryar Blue came with the Blue interior that was used in the Targa Blue Vettes. It never was offered as a ( New car ) optional interior color at first for the Bryar Blue Vettes BUT they did offer it as time went on. They really do not match.
Old 07-01-2016, 11:30 PM
BLUE1972
BLUE1972's Avatar
I always loved both colors.
When my friend parks his 67 Marina Blue next to mine the Targa Blue takes on a Purple tone, Kind of looks cool.
If I knew now .. when I purchased the car there was a Steel Cities 71 also on consignment - bare car no options - I would have bought it as I love that color also. It had a 4 speed & 4:11 rear that is why I passed. (the 4:11 rear)
My 72 is loaded all options except the rear window defogger.
C3's at Morgan Park ... in year order
To Stock 67 thru 72 Vette open element air filters
Quick Reply: Stock 67 thru 72 Vette open element air filters
