★NEW!! Quiet Down Your Interior in Seconds!! / Blockit Sound Deadener Solutions!
Premium Supporting Vendor
Location: ★ Performance Parts & Accessories ★ 1800 778 9898
St. Jude Donor '07-'08-'11-'12-'13-'14-'15-'16-'17
Reduce Interior Noise IN SECONDS!!
Reduce interior noise in SECONDS by simply dropping in the pre cut BLOCKIT sound deadening mats right over your existing carpet! No Adhesive!
This is NOT a thin single layer mat.
The BLOCKIT is a unique 4 infused layered combination of real acoustical soundproofing which measures 1" thick! It's patent pending design absorbs and suppresses unpleasant sounds that leak into your C4's cabin.
It’s perfect for taking that annoying edge off tire / road noise & some aftermarket exhausts in your coupe. NO need to rip out your carpet & interior! The precision pre cut BLOCKIT Sound Deadening System lays right over your carpet!
[SIZE="3"]Fits All 84-96 Coupes. One large piece fits perfect in your cargo area. One piece goes behind each seat.
The durable UV protected top layer looks great and allows you to still use your cargo area. Feel free to place an aftermarket cargo mat on top!
* Reduce Interior Noise In Seconds
* Immediately removes Tire/Road Noise & Some Aftermarket Exhausts.
* Pre - Cut & Shaped! No Adhesive! Lays Right Over Your Factory Carpet
* Fits all 84-96 Coupes
* Has a Slit For Easy Access To Cargo Doors
* No Ripping Up Your Carpet/Interior
* 4 Infused Layers Of REAL Acoustical Soundproofing Materials
* 1" inch thick!
* 3 Piece Pre-Cut Kit
* Great For Long Trips
* UV Protected Top Layer is Durable & Looks Great!
* Made In The USA! Raw Materials From The USA Too!
* Manufactured under strict ISO 9001-2008 standards!
* Patent Pending
★ IN STOCK READY TO SHIP
http://store.tkoperformance.com/84qquprecuts.html
________________________________________ __________
With the success of our Blockit pre cut Quick & Quiet “Drop in” Mats it was only natural for us to create more fantastic sound deadening/damping products!
Great for other areas of your Corvette, any generation Corvette, any make & model car or truck!
Blockit DeadMats
• Extremely effective at eliminating unwanted vibrations, noise & rattling!
• Light Weight!
• Performance to weight ratio is amazing!
• Improve your audio’s sound quality!
• Textured top layer looks great once installed! (No "tin foil" appearance!
• Very durable. Won’t rip, tear or break down overtime!
• Helps reduce heat!
• Simple peel and stick application!
• Apply to any make or model where it’s needed!
• All raw materials are from the USA!
• Made in the USA!
• Manufactured under strict ISO 9001 regulations
• A Great Addition to the Blockit “Quick & Quiet” Mats
Blockit Dead Mats use a unique technology to eliminate unwanted vibration & noise in your vehicle.
It’s not your typical mass loaded vinyl. The light weight mats are a highly damped proprietary mineral filled viscoelastic polymer which provides outstanding sound & vibration reduction. At only .445 lbs per sq ft the performance to weight ratio is amazing. The bottom line is The Blockit DeadMats are designed to simply not vibrate!
The self adhesive backing makes for a simply cut and stick application. Thin so its easy to work with and you can place it almost anywhere. You can either completely cover an area, just a portion of an area or strategically place them with outstanding results. Blockit Dead Mats can be stacked to double up on vibration and noise reduction. Blockit Dead Mats, are fantastic on their own or in addition to compliment the Blockit Quick & Quiet Mats.
We know there are some areas that require damping and are not hidden or buried under carpet. The Blockit Dead Mats have a textured surface layer which is durable and has a nice clean look when exposed.
Available in:
★5 18"x32" Sheets (20sq ft) http://store.tkoperformance.com/bldema185sh2.html
★9 18"x32" Sheets (36 sq ft) http://store.tkoperformance.com/bldema18x329.html
or 9 18"x32" sheets
Under a C7 Seat
Cargo
Door
Click Here to watch what a small 5" piece of DeadMat does! Imagine what DeadMats can do for you!
Available in:
or 9 18"x32" sheets
Your 84-96 Corvette is an American icon. Treat it right with actual acoustical material made here in the USA! Even our raw materials are from the USA.
All made under strict ISO standards. Patent Pending
Ed
__________________
Serving The Corvette Forum For 21 Years!!
Allow us to add you to the list of extremely satisfied customers.
Order Securely Online 24/7: http://tkoperformance.com/index.html
Feel Free To Contact Us By Phone: 1800 -778- 9898 Monday- Friday 9:00am to 4:30pm
Click Here: http://www.facebook.com/pages/TKO-Pe...e/367433626633
The Blockit "Quick & Quiet" 3 piece mats, have been out for a while taking care of C5, C6 & C7's. Here are some comments I grabbed from here on the forum.
I installed the Blockit sound insulation mat and the behind the seat panels this weekend and I am very impressed. The mat just goes in the hatch area and the fit is excellent. I installed the two panels that go behind the seats behind the carpet. The carpet in that area is not tacked down so it is easy to do.
The mat looks very polished in the rear cargo area so I don't think that I will add an aftermarket cargo mat on top of it.
While commuting to work this morning on the freeway I really did notice a difference. I did not have to crank the radio way up and the voices and music were much clearer.
If you are looking for a real easy sound insulation solution I would recommend this product.
I just put one in my '05 coupe. The difference in interior sound was instantly noticable. After cranking it up I had to put the window down a little to make sure the engine was running OK.
It did however, take me double the 30 second recommended install time, due to me flopping it in there upside down and then having to take it out and flip it over because I didn't read the instructions.
I got mine yesterday and installed it last night.
First drive to work this morning and I can tell you it makes a big difference. Those that say it doesn't must have some really frickn' loud exhausts.
It took the resonance away that the road puts through the rear hatch area (hatch floor, plastic) and the road noise from the tires is probably cut in half.
There's also a noticeable "quietness" inside the rear now that I never had before. I always had that "white noise" behind my head from all the noises coming from the rear hatch area. Now it sounds like the entire car is quieter.
It made such a difference I am no longer worried about putting dynamat or peel and seal in my car. I will however still do the peel and seal on the floor boards under the car because now that the rear is so much quiter I hear road noise from under the car... lol.
Overall, it's a great buy and I'm glad I bought mine!!
To start with, I am not a vender and do not sell these things, but WOW! What a difference. I have an 05 vert with borla stingers and love the sound. But on the interstate and highway speeds, the car is just kind of loud. Not just from the exhaust, but from road noise. So I bought the new "blockit' insolation kit sold here on the forum. Not the kind that requires you to remove the carpet or anything. Just put two pads behind the seats and one pad in you truck, or cargo area for a coupe. I drove my car at 70+ MPH for a good ways last night and WOW!!! Much smoother and peacefull sound. The stereo sounded better and the car just seems so much quieter in the cab area. I have had a C6 coupe and now have a C6 vert, and I promise you, this thing works! Just wanted to shout out a nice mod.
I was at Carlisle and the Blockit was sold out, so I bought the demo kit that was inside the Corvette parked under the TKO tent. In my opinion, it was worth it because it works. My C6 is very loud, as it is cammed, etc., with headers & NPP. It has an annoying low rpm drone. With muffler flaps open it is unbearable for cruising below 1,950 rpms. Even with flaps closed, the drone was very annoying below 1,950. Most of my cruising is between 1,700 and 1,950 rpms in 6th gear with 4.10 gears. With the blockit installed, the drone is gone at these rpms with flaps closed. Not just reduced, but gone. Below 1,700 drone is reduced to a bearable level.
With muffler flaps open the drone is reduced with the kit, but still louder than my comfort level. But it's a moot point now.
Having had Blockit in my Z06 - I thought it did a great job reducing noise so I added it to the C7 - Z51.
It arrived packaged well. Easy install with a precise fit. I was able to use the rings and shade. I found it able to make a nice noise reduction on all surfaces around Little Rock including interstate and different road surfaces including concrete and asphalt.
I'm very happy with the product!
Installed on my C7 Z06. TRANSFORMATIONAL! The reduction in tire noise is astonishing. Being an engineer I had planned to use my laboratory dB meter to measure noise levels with and without the TKO Blockit kit. As it turns out there is no need to do so because the noise reduction is truly dramatic. This kit is a "must have" for all but deaf C7 owners. I had a '14 Z51 which had hellacious tire noise. I was exhausted after driving it for 3-4 hours. The '15 Z06 was significantly quieter and rides more smoothly....think Chevy vehicle engineers softened the suspension bushings. Seems to be well known that the '15 is a quieter car. Just can't believe how such a relatively inexpensive and easily installed kit can be so effective. I could now drive the car across country....yes, it's that good.
Well, I had a chance to test drive my car on some roads that previously had some serious tire noise due to the road conditions. For the ease of installation and simpleness of the product; I'm very pleased with the it. I was able to lower my radio volume from where it used to be, and hold conversations without raising my voice. In fact I am now aware of other noises that I hadn't previously heard.
So bottom line: I'd recommend(your hearing my vary) .
I can't say it's equal to the kits that require full interior dis-assembly since I didn't do that, but I definitely feel there is value in the product. If you are in Southern Calif and want to try in your car, come by and we'll throw it in and you can hear for yourself. Or just take my car for a test drive.
Tom
Tom
Received my set of sound deadeners yesterday and promptly installed them in about 10 minutes.
Started the car in my garage and could hardly hear the exhaust with the windows up. Backed it outside ( a lot of snow here now ) and tried the same thing, windows down ,windows up. I will not get to take the Z06 out until spring, but I can tell you that there is a substantial difference in the noise factor just sitting in the car and listening to it run.
Great product. Can't wait to do a more extensive test in the spring, but initially this seems to be a great product !!
Many thanks,
Dave
Many thanks,
Dave
Just got my Blockit mats today and did a roadtest on the concrete I16 around Savannah and a couple miles on local black top.
Super easy install - drop in and forget it. I have a coupe.
Big rear mat had the slits for rings.
Put my Stingray logo rear carpet on top of the mat and also put the mats behind the seats.
I can tell a difference in noise ; can hear the radio better and believe a long cruise will be far more pleasant.
I have the Blockit mats. My wife can hear like you wouldn't believe. She is the perfect test for these. She stated to me that there was a significant difference in sound reduction. That's good enough for me. I thought there was a difference too, but I didn't want to rule out wishful thinking on my part so I had her listen before and after.
I put it in my 2016 Z06 last week and the difference is very noticeable. Less tire noise, radio volume setting is lower now and much more enjoyable. As another poster noted the exhaust sound now stands out more; my Z06 exhaust is normally set to track mode.
I did notice the action of the Bose audio pilot (auto volume compensation) is much more noticeable now and I turned it off.
How thick are the peel and stick mats?
Wow! Had a killer Friday at Carlisle! We met up with a bunch of Forum members. Great stuff...
Nothing but beautiful weather on the radar!!
We sold a ton of Blockits. If your interested we will be there Saturday only. Spots ID 106, 107, 108 (down the row of the front of the Grandstand)
On sale AND you save $35 in shipping too!!!
Here are some Blockit Posts from forum members..
Tom
Tom
Many thanks,
Dave
Many thanks,
Dave
New batch of Blockit Quick & Quiet mats were made. In stock and ready to ship
Thank you for he orders! Orders are shipping as promised. Tracking numbers are being emailed
HAPPY NEW YEAR!!
All orders received over the holiday weekend will ship tomorrow 1/3
Here's to a fantastic 2017!
All orders that were placed from 2/15on are going, going.....GONE!
Thank you for your business
Ed
Ed
