Brake bleeding problem, no fluid at LF?
Old 04-13-2014, 06:54 PM
jv9999
jv9999's Avatar
Default Brake bleeding problem, no fluid at LF?
I was vacuum bleeding the brakes on my '87 today. All was going well, did RR, LR, RF, then I got the LF... Brake fluid will not come out of that hose no matter what I do. I even pulled the line off the caliper and pulled a vacuum on it (using a motorized vacuum pump) and nothing. Pumped the pedal, no fluid. ABS pump blocking it?
Ah, and the booster is bad too. Won't hold a vacuum. Having fun!
Old 04-13-2014, 07:06 PM
hooked073
hooked073's Avatar
colasped hose would be a fast quess
Old 04-13-2014, 07:13 PM
DUB
DUB's Avatar
Received 2,713 Likes on 2,321 Posts
Remove the rubber hose from the steel line...and see if fluid comes out...if it does...you have a bad hose.
DUB
Old 04-13-2014, 08:37 PM
pcolt94
pcolt94's Avatar
A bad hose would really be a nice easy fix.
But if you do remove the flex hose and no fluid comes out, it's probably the ABS unit. There was a lot of clogged ABS units several years back as I remember.
Old 04-13-2014, 08:50 PM
jv9999
jv9999's Avatar
I hope it's as simple as a collapsed hose, but if it's like everything on this car it will be the worst possible cause :-)
It's a one owner car with 60K on it, but it's keeping me busy and constantly attacking my wallet.
Old 12-09-2015, 01:55 PM
vetteboy88
vetteboy88's Avatar
Realize this is several months old, but just wondering how you made out. I have the same issue with the RF caliper releasing very slowly. Foolishly, I threw parts at it before realizing it was the ABS pump. Have another issue with the abs after trying to remove a relay; it fried a wire in the harness. Was able to get a salvage one, but haven't installed it yet. Just wondering how your problem went....
Old 12-10-2015, 09:51 PM
jv9999
jv9999's Avatar
I managed to free the solenoid that was stuck, but honestly you're better off just finding a good pump.
Old 12-11-2015, 04:30 PM
barbedwiredave
barbedwiredave's Avatar
How did you get it free?
To Brake bleeding problem, no fluid at LF?
Quick Reply: Brake bleeding problem, no fluid at LF?
