Where is the RTD module located on a 2000?
Exactly as the title says. I had the F45 option on my car and I took it off. I removed the code with a TECH II but it didn't work. I read that you have to disconnect the RTD module first, then remove the code. Where is this module located on a 2000 C5? I searched but couldn't find anything on the actual location of the unit.
Thanks!
Thanks!
RTD Electronic Suspension Control Module Description
The ESC module provides electronic control logic and output drive for each shock absorber solenoid. The ESC module makes decisions due to road and driving conditions based on various inputs. The ESC module receives input information by sensors that are directly connected to the ESC module or by other systems through the serial data line.
The ESC uses these inputs in order to independently control the shock absorbers at each corner. The ESC module is located in the LH rear storage compartment.
Document ID# 582630
2000 Chevrolet/Geo Corvette
Document ID# 582630
Received 2,180 Likes
CI 6,7,8,9,11 Vet
St. Jude Donor '08
As it is on ALL F-45 C5s
