Parts for LS6 Intake Swap on to a LS1 Block
Old 05-12-2009, 03:20 PM
QuickKid
8th Gear
QuickKid's Avatar
Default Parts for LS6 Intake Swap on to a LS1 Block
I recently found a good price on a LS6 intake manifold. I would like to swap it onto my '98 LS1 engine. Are there any parts beside the manifold that I need for the swap?
Old 05-12-2009, 03:32 PM
Bill Curlee
Support Corvetteforum!
Bill Curlee's Avatar
Received 2,180 Likes on 1,583 Posts
CI 6,7,8,9,11 Vet
St. Jude Donor '08
I would carefully inspect the re-usable intake manifold gaskets and make sure they are in good shape. If not, get new intake port seals.
Other than that,,,your going to need to purchase a 2001 + coolant cross over block off plugs and a 2001+ front coolant cross over pipe.
If you want to retain the 97-98 style coolant crossover pipe, you will need to trim off some of the webbing on the BOTTOM of the intake to allow the small coolant pipe that runs from the front to the back of the engine under your old manifold to fit under the new one. I recommend trimming the manifold. Its prettu easy and doesnt hurt the manifold.
Put some white paint on the coolant pipe and press the LS6 manifold down firmly on to the engine. The white paint will transfer to the webbing and trim a 1/8" on either side of the paint mark.
BC
Old 05-12-2009, 05:20 PM
chuckster
chuckster's Avatar
BC
I love your thorough Answers..!!!!
Old 05-12-2009, 05:54 PM
C5ZLind
C5ZLind's Avatar
I just did this swap and i would suggest go ahead and change the seals i picked some up for around 25$ for the seals and new foam pads..It would suck to have to remove the intake to replace seals.
Keith
Old 05-12-2009, 06:47 PM
Daddyrama31
Daddyrama31's Avatar
replace your intake gaskets, you can get them at any auto parts store for about 25 bucks. I would remove the coolant pipe and replace with the new LS6 cross over tube. It's an easy switch. Leaving that tube underneath has been known to crack the intake. If you are going to do it, do it right. GM part# 1262544 54 bucks, and two plugs to plug off the rear GM Part# 12602540, 8 bucks each. You will not regret the switch!
Old 05-12-2009, 07:47 PM
LoneStarFRC
LoneStarFRC's Avatar
Location: Dear Karma, I have a list of people you missed.
BC
Use white shoe polish. Wipes right off after. Paint not so much.
To Parts for LS6 Intake Swap on to a LS1 Block
Quick Reply: Parts for LS6 Intake Swap on to a LS1 Block
