228r gain bad
228r gain bad
hi folks
I was at 305whp on my c5 a4 stock
Put a 3.42, 2800 stall, 228rcam and spring. Push rod and 243 head
367wrhp
Broke 243 head, was castech casting, put back my 241 head with spring
317whp. Normal ?
367wrhp
317whp. Normal ?
Received 1,261 Likes
so you have one 243 head and one 241 head installed on the car??... was the tune adjusted after you swapped heads?
You aren't going to get much hp gain on stock heads, especially when the cam isn't designed for it. I wouldn't waste time on a retune until you get proper heads.
Received 2,180 Likes
CI 6,7,8,9,11 Vet
St. Jude Donor '08
What did you do to the 243 head??????????????
Who did your tune and how was it tuned???
do a compression and leak down test... add headers and get it retuned
This picture is a straight up install. If the motor was rotated before the timing chain was installed then the cam will not open the valves correctly.
