Timing Cover Seal Replacement
I originally posted this in the C5 General Category but see that it is more appropriate here:
I did a head a cam swap on my 99 C5 a few years ago and followed the LS1Howto process. I must not have gotten the timing cover aligned correctly and am going to have to replace the seal. When I swapped the cam, I had to remove radiator to allow enough room to pull the cam out of the block. I'm thinking there should be enough room to pull the balancer (after moving the steering rack) and remover the timing cover without removing the radiator, but just checking to see if anyone has done it and knows whether the radiator can stay. Thanks
Received 2,180 Likes
CI 6,7,8,9,11 Vet
St. Jude Donor '08
NO need to remove the radiator. When you replaced the cam, did you install a new Balancer??
The OEM GM Front Cover seals were very hard and had a tendency to SCAR the dampener sealing surface. My old seal carved out a large area of sealing surface. I had OIL E V E R Y W H E R E!!!!!!!!!!!!!!!!!
rcwilbur (05-31-2016)
When you replace the seal, leave the timing cover lose and install the harmonic balancer.
THEN tighten down the timing cover. If it's bolted down before the harmonic you have a chance that the seal wont be centered.
This is how I did mine and it's bone dry.
THanks for sharing the picture.
I would highly recommend using one of these alignit tools from saccity corvette. Allows you to line up the front cover with excellent accuracy. They make one for the rear cover as well. However, if you've already installed the seal in the front cover, it's too late. Can't get the seal out without destroying it. You could however just buy another seal.
http://www.saccitycorvette.com/AlignItTools.html
CI 6,7,8,9,11 Vet
St. Jude Donor '08
No problem my friend... Glad to be able to help you resolve your issue.
Bill
Bill
Don't follow LS1howto on this. The methods just make a mess of things and can lead to damaged crank threads from damper removal and installation. All of the RTV he puts on the bottom of the timing cover is unnecessary and makes a mess. His torque value for the GM bolt is wrong as well.
Put dabs in the corner per the service manual and correctly align with the tool you bought and it shouldn't leak.
Thanks. I'll take a look at the installation instructions and the torque specs in the service manual.
When I got the timing cover off, the crank seal was so loose I could spin it in the opening with my finger. I grabbed it and it almost fell out into my hand. I'm wondering if perhaps the seat is damaged from the seal spinning in the opening? I have not seen anyone describe this as a problem in anything I read, but am really trying to avoid having to do this again if at all possible.
Thanks.
Thanks.
A short follow-up on my prior post. I installed a Summit Balancer SUM-C2501--an upgrade from the OEM balancer but not as expensive as the ATI balancer. I used Felpro gasket/seals and an ARP crank bolt.
Everything went back together well and I am now enjoying the car without oil being sprayed throughout the engine compartment. And surpringly (at least to me) the car seems to run better, especially at idle. Makes me enjoy driving the car again. Thanks again for everyone who responded. Carl.
