6 sp and diff fluid change. Opinions please.
Old 09-01-2016, 08:44 PM
cloud 9
cloud 9's Avatar
Default 6 sp and diff fluid change. Opinions please.
So while I have it all torn apart, doing a clutch job in a 97 6 speed. 88k miles. Should I change the tranny and diff fluid? Opinions on what I should use and how much to buy? I am a spirited driver, so she gets a good workout most times I drive it.. TIA
Old 09-01-2016, 08:55 PM
Macleod52
Macleod52's Avatar
If you don't know when they've been changed then definitely. I would change them every 3-5 years if it were me. As far as what to use and how much I can't say.
Old 09-01-2016, 09:10 PM
grantv
grantv's Avatar
I did Amsoil for both. Torque Drive x 4 quarts (uses a bit less) and 75/90 Severe Duty x 2 quarts (less used again). Did mine around 45K miles.
Old 09-01-2016, 09:11 PM
FASTFATBOY
FASTFATBOY's Avatar
Put synthetic in the car if your going to do it. I just put this in the trans, seems to like it, I have a six speed.
Old 09-01-2016, 09:16 PM
neutron82
Support Corvetteforum!
neutron82's Avatar
Received 1,261 Likes on 1,056 Posts
buy 4qts for the trans and 2qts for the diff and you will likely have a small amount left over from each... I am a fan of amsoil torque drive and severe gear 75/90, been using that in my car since I bought it and never had an issue with the drivetrain... I have never used the diff addidive with the amsoil severe gear and haven't had any noises so I don't think it is needed... I change mine out religiously though, once every year or so regardless of mileage
Old 09-01-2016, 09:19 PM
FASTFATBOY
FASTFATBOY's Avatar
And don't overfill the diff, you will create an axle seal leak.
If the car is on a rack or level let the fluid run out of the fill plug until it stops when you fill it. Put the plug in and you're done.
Old 09-02-2016, 08:52 AM
73Corvette
73Corvette's Avatar
Old 09-02-2016, 12:07 PM
Bill Curlee
Bill Curlee's Avatar
Received 2,180 Likes on 1,583 Posts
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Your 97 has paper Synchro blocker rings and synthetic ATF can damage them. NOT RECOMMENDED to use synthetic ATF in your trans.
Either use an OEM Compatible ATF or use the AMSOIL Torque drive trans fluid! They don't make DEXTRON III any more but there are compatible dino stock ATF fluids..
I HIGHLY RECOMMEND the AMSOIL Product!
When you drain and fill, you will only be able to fill to 3.75 qts.
A NEW DRY NM6/NM12 will take 4 qts.
BC
Pounder (09-02-2016)
Old 09-02-2016, 01:22 PM
craig-o
craig-o's Avatar
I followed these instructions the first time I changed the Dif fluid (consistent with the factory service manual), and had a leak out of the driver's side. I figured it was the seal that commonly goes bad, and I was in for a bigger job. Then, someone suggested taking the car out for a drive to get the fluid up near operating temperature, parking on a level surface and opening the fill plug (without lifting.) More fluid came out; don't remember how much, but that solved my leak - and it's been leak-free for the 105,000 miles and 2 more fluid changes since using this technique.
I'm dubious that this is due to thermal expansion, and more likely what appears level to me on jack-stands might not actually be. But if you're doing this in the garage, after you lower the car back onto the ground, there's more than enough space to reach the fill plug. Check the level with the car back on the ground. And if you get a leak, try warming up the fluid and checking the level again.
Old 09-02-2016, 04:17 PM
jackthelad
jackthelad's Avatar
They actually do make Dexron III fluids - they are just not allowed to call them that any more, due to GM's control of Dexron as a trademark. My '98 is running Valvoline DexMerc, which is labelled for older GM cars which require Dexron III. Get it from pretty much any autoparts shop - plus Walmart sells it by the gallon jug. Non synthetic, works just fine.
I was surprised just how much difference to smooth shifting a tranny oil change makes. Vowed to do more it regularly in future.
Old 09-02-2016, 08:46 PM
cloud 9
cloud 9's Avatar
So are there any Amsoil vendors around here I can get some from?
Old 09-02-2016, 09:06 PM
neutron82
neutron82's Avatar
I usually just buy direct, that's the easiest for me... they have a distribution center nearby so I typically get my order in a couple of days
Old 09-03-2016, 12:46 AM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
I have a local Bumper to Bumper that stocks it. Try NAPA and just remember,,,,,,,,,,,,,,,,,,,,,,,,,,,,, GOOGLE is your friend..
Bil
Old 09-03-2016, 12:40 PM
spdislife
spdislife's Avatar
I use the same thing, but if you're not planning on tracking the car I think most brands will be fine regardless of spirited driving or not.
Old 09-03-2016, 06:58 PM
cloud 9
cloud 9's Avatar
I'll go with the good stuff for my baby. So the Amsoil Torque Drive ATF for the 6 speed stick? I guess I have never heard of 6 speed standard oil..
Old 09-03-2016, 07:35 PM
Geewhiz
Geewhiz's Avatar
I would definitely change both.
I used Royal Purple, MAX ATF, it is recommended on their website.
I used Lucas Oil's product for the diff. All synthetic.
Car shifts smoother than before. Lot's of good products, Red Line, Amsoil, etc. All a personal choice. Enjoy.
Old 09-26-2016, 07:59 PM
cloud 9
cloud 9's Avatar
Thank you for all of the replies! So the clutch job went well. I replaced the fluids with the Amsoil products some of you suggested. I installed my c6 shifter, threaded it and put my c5 ball on it. I put a washer in the detent on the transmission. The combination made a world of difference in shifting. I love it. Feels like it should
To 6 sp and diff fluid change. Opinions please.
Quick Reply: 6 sp and diff fluid change. Opinions please.
