6 Speed guys which trans
With the higher hp cars which trans are you using, T-56 or TR6060? I am at the point where I going to have the trans upgraded and don't know if I want to go with a level 5 T-56 or swap over to a built TR6060. Right now I am at 700 hp and have plans to build a motor later this year or next and try to reach 1000 hp.
Location: Greater Detroit Metro MI, when I'm not travelling.
T6060 on left, T56 on right:
Because it has a pump up front to spray lube on the gears and bearings to keep them cool and lubricated, especially under hard acceleration, when the fluid is pushed rearward and away from the front bearings.
That's one of the reason to get the TR6060.
St. Jude Donor '09-'10
RKT56 or RPM can supply with the needed stuff.
The OP asked about power; the 6060 will handle more HP no questions asked.
