C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Motec M150 to Vette with factory BCM?
Old 06-29-2015, 10:12 AM
  #181
Tuomas FIN
Tuomas FIN's Avatar
Picked up the car today from the dyno and talked further with tuner. It looks cyl 5 is not the only one but it's worst. Cyl 7 looks as well same problem a bit.
Old 06-29-2015, 10:32 AM
  #182
Tuomas FIN
Tuomas FIN's Avatar
Launch test
Old 06-29-2015, 11:19 AM
  #183
Unreal
Unreal's Avatar
Received 2,313 Likes on 1,793 Posts
I wonder what size springs my PRC heads will take. I'm running PRC 650s and want to swap them out to something to support a bit higher RPM. Running Ti intake, SS exhaust on a fairly mild cam (230/246 LXL/LXL). Sounds like PAC1207X might be a good upgrade.
I love threads like this because you can get solid tech in them along with the car ****.
Old 06-30-2015, 12:04 AM
  #184
JBrantoni
Navigator
JBrantoni's Avatar
I'm running motec and proefi on my car
Old 06-30-2015, 01:37 AM
  #185
Tuomas FIN
Tuomas FIN's Avatar
You have motec dash instead oem instrument cluster?
Old 06-30-2015, 09:51 AM
  #186
JBrantoni
Navigator
JBrantoni's Avatar
Yes. Was all 3d printed at d3
Old 06-30-2015, 10:50 AM
  #187
Tuomas FIN
Tuomas FIN's Avatar
Can you shoot more pictures how its done, I wanted myself keep oem cluster because street car but very curious how dash looks.
Old 06-30-2015, 12:42 PM
  #188
JBrantoni
Navigator
JBrantoni's Avatar
My cars still 100% street able and he motec display is awesome. Considerably better than any other option. I'll message you some pictures this evening
Old 06-30-2015, 03:48 PM
  #189
JBrantoni
Navigator
JBrantoni's Avatar
Old 06-30-2015, 11:17 PM
  #190
inspector12
inspector12's Avatar
LOL! I love your term Street able lol! Yeah I was there when Dave finished the 3D insert and installed it in your car. It was a very cool piece and crossed my mind, but the price tag put it out for me when all my factory gauges work fine. But you baller guys can swing that stuff no problem with your huge pocket books. Yeah I'm jealous lol! Your car could be impressive. but I saw I go together and while you might drive it on the street etc... Its more race car than street car lol! But a bad MF for sure! I mean everyone should have a pair of rain catcher DP's sticking out the hood!
Old 07-06-2015, 06:16 AM
  #191
Tuomas FIN
Tuomas FIN's Avatar
Springs measured.. Looks low.. In few days should arrive PAC 1529's
Old 07-06-2015, 08:56 AM
  #192
slow ride
slow ride's Avatar
Nice documentation They look like they might have been better off with a shim under them to get the install height down to 1.800" or less which would bump operating pressure up overall. They are probably not junk, but the new springs will give you a edge in pressure. I'd measure those also and make sure they all set up where you would want. Good job though.
Old 07-06-2015, 11:42 AM
  #193
Tuomas FIN
Tuomas FIN's Avatar
Yeah thanks!! Absolutely I will measure each valve installed height as well new springs and will shim if necessary.
Old 07-06-2015, 02:55 PM
  #194
Tuomas FIN
Tuomas FIN's Avatar
Looks really nice, I'm very curious how much $$$ was the insert w/o dash??
Old 07-07-2015, 01:14 AM
  #195
Tuomas FIN
Tuomas FIN's Avatar
Originally I made back pressure measuring only to the passenger side but now due to valve issues want all the information available so welded the plug to driver side as well. At same had to turn bit cyl 7 lambda plug make some extra clearance for sensor. In plans add LTCD's for every cyl instead EGT's. And filter side pressure measuring next to turbine wheel.
I have dash in test use as well, it's temporary installed now. Just thinking if replace oem cluster..
Old 07-07-2015, 03:24 AM
  #196
chuntington101
chuntington101's Avatar
Sorry for daft questions but what are LTCDs? I thought EGTs per cylinder should give you all the info you needed. Do to you also have O2 sensors per cylinder also?....
Old 07-07-2015, 11:26 AM
  #197
Tuomas FIN
Tuomas FIN's Avatar
http://www.motec.com/ltcd/ltcdoverview/
Yeah, lambda per each cylinder.. EGT's works slow compared CAN O2 sensor..
To Motec M150 to Vette with factory BCM?
Old 07-07-2015, 12:31 PM
  #198
Pekka_Perkeles
Pekka_Perkeles's Avatar
Tuomas, do you use GM knock sensors, or is there a better way to do it in your case (Motec)?
Old 07-07-2015, 12:50 PM
  #199
Tuomas FIN
Tuomas FIN's Avatar
Still factory sensors, on dyno additional headset.
Old 07-07-2015, 02:24 PM
  #200
slow ride
slow ride's Avatar
Jealous man, data for days.
Quick Reply: Motec M150 to Vette with factory BCM?
