Screen flicker
Old 07-30-2016, 03:44 PM
red 1
red 1's Avatar
Originally Posted by irpete
Took mine to the dealer 10 days ago and they agreed to replace the screen however GM says the screens are on backorder with no timeframe of when they will have more.
Same exact issue.
Old 08-18-2016, 09:29 PM
irpete
irpete's Avatar
Anyone who has the screen on backorder get theirs in yet? It's been a month now on backorder with no updates.
Old 08-18-2016, 10:48 PM
Bounty Hunter 6
Bounty Hunter 6's Avatar
Originally Posted by globexam
2014 Stingray with nav and without prediction or reason, the info screen will "roll" bottom to top or "flicker" bottom to top. Nothing stops it short of turning off and back on. Anyone else observing this?
This sounds funny, bear with me. Until you get it replaced, when it flickers, honk the horn. Just barely have to tap it and it stops the flicker. Even if the screen goes completely black, honking the horn will make it come back. Silly, right? Mine hasn't flickered in 3 months now.....
Old 08-19-2016, 08:44 PM
rrod436
rrod436's Avatar
After a month and a half, I finally got my replacement module. We'll see if it's fixed for good over the long haul.
Old 08-20-2016, 08:19 AM
red 1
red 1's Avatar
I called the dealer yesterday and was told my screen had arrived and to bring my car in Monday morning.
Old 08-22-2016, 02:38 AM
whosurdaddy107
3rd Gear
whosurdaddy107's Avatar
I tried it and it work! thanks. so do you think i should try to get a new screen? i wont be able to show the dealer since it work now.
Old 08-22-2016, 06:49 PM
irpete
irpete's Avatar
Mine finally came in as well as was replaced this weekend. So far no issues.
Old 08-06-2017, 06:43 PM
ferraf
Support Corvetteforum!
ferraf's Avatar
Originally Posted by waheed4312
dear all
I am working on screen flicker problems
found the wires going in to screen, usb connector losses and wire locking cable tie with body very tight . remove or cut ties .problems will solve automatically
regards
waheed
where do I get to the ties?
Old 08-22-2017, 03:54 PM
Mike Mercury
Mike Mercury's Avatar
Mine just went totally blank - after a month of intermittent operation. The radio still worked, just the screen was blank. Sometimes if I pressed in on the upper right corner of the dash plastic bezel (not on the radio screen itself - but the plastic dash bezel that surrounds the screen)... it would come back on and work for awhile. Eventually it just went blank permanently.
With just 3 weeks to go until warranty ends, I got it to the dealer yesterday.
-whew-
Their service writer said "yep, we've replaced about 4-5 screens in C7's so far".
I'm not so certain it actually requires a replacement part, as it acted like a loose cable/connector. But the dealership is determined to replace the screen... and that's fine by me.
ferraf (08-22-2017)
Old 08-22-2017, 04:21 PM
ferraf
ferraf's Avatar
Thanks Mike, I brought it in and after 2 days they determined the "control module" was faulty and should be replaced. Now 4 days in GM has the "control module" backordered with no ETA to far to replace....
Thanks!
Old 10-12-2021, 03:49 PM
paladin109
1st Gear
paladin109's Avatar
Default Flickering screen
What is the module that needs to be replaced for the flickering screen?
Quick Reply: Screen flicker
